ROS2 Basics in 5 Days: Course Project : ros1 bridge error
Hello !
I’m doing the project for ros2 basic. I’ve reached the part with the services.
It’s working in the simulation. When I try it on the real robot.
I used the code provided in the notebook :
ros2 run ros1_bridge parameter_bridge
But I get the following error. Also, in this case, if I want to build after adding a code, which source should i source, and I will navigate to the ros2_ws when i write colcon build ?
Thanks,
Hi @BushraAlsh, I think you might have an older version for your project, since it is no longer required to run the ros1 bridge. Everything runs in ROS 2.
Here are the latest rosjects:
Now I understand , and it works. Thanks!
