I’m attempting to build the action server for section 3 of the Rosject for ROS2 Basics in 5 Days: Course Project. I’ve successfully built the packages after changing around the OdomRecord.action file.
Documentation shows:
geometry_msgs/msg/Point[] list_of_odoms
float32 current_total
This caused problems during the build. A search of the forums shows this as a solution:
OdomRecord.action
geometry_msgs/Point[] list_of_odoms
I created a launch file just for the action server to make sure everything with the server was ok. When launching the action server I get this error:
user:~/ros2_ws$ ros2 launch wall_follower action.launch.py
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2024-03-04-23-03-03-892993-1_xterm-5391
[INFO] [odom_recorder-1]: process started with pid [5393]
[odom_recorder-1] Traceback (most recent call last):
[odom_recorder-1] File "/opt/ros/foxy/lib/python3.8/site-packages/rosidl_generator_py/import_type_support_impl.py", line 46, in import_type_support
[odom_recorder-1] return importlib.import_module(module_name, package=pkg_name)
[odom_recorder-1] File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
[odom_recorder-1] return _bootstrap._gcd_import(name[level:], package, level)
[odom_recorder-1] File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
[odom_recorder-1] File "<frozen importlib._bootstrap>", line 991, in _find_and_load
[odom_recorder-1] File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
[odom_recorder-1] File "<frozen importlib._bootstrap>", line 657, in _load_unlocked
[odom_recorder-1] File "<frozen importlib._bootstrap>", line 556, in module_from_spec
[odom_recorder-1] File "<frozen importlib._bootstrap_external>", line 1166, in create_module
[odom_recorder-1] File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
[odom_recorder-1] ImportError: /home/user/ros2_ws/install/odom_interface/lib/libodom_interface__rosidl_generator_c.so: undefined symbol: geometry_msgs__msg__Point__Sequence__init
[odom_recorder-1]
[odom_recorder-1] During handling of the above exception, another exception occurred:
[odom_recorder-1]
[odom_recorder-1] File "/home/user/ros2_ws/install/wall_follower/lib/wall_follower/odom_recorder", line 33, in <module>
[odom_recorder-1] sys.exit(load_entry_point('wall-follower==0.0.0', 'console_scripts', 'odom_recorder')())
[odom_recorder-1] File "/home/user/ros2_ws/install/wall_follower/lib/python3.8/site-packages/wall_follower/odom_recorder.py", line 92, in main
[odom_recorder-1] odom_action_server = OdomActionServer()
[odom_recorder-1] File "/home/user/ros2_ws/install/wall_follower/lib/python3.8/site-packages/wall_follower/odom_recorder.py", line 17, in __init__
[odom_recorder-1] self._action_server = ActionServer(self, OdomRecord, 'record_odom', self.execute_callback)
[odom_recorder-1] File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/action/server.py", line 249, in __init__
[odom_recorder-1] check_for_type_support(action_type)
[odom_recorder-1] File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/type_support.py", line 29, in check_for_type_support
[odom_recorder-1] msg_type.__class__.__import_type_support__()
[odom_recorder-1] File "/home/user/ros2_ws/install/odom_interface/lib/python3.8/site-packages/odom_interface/action/_odom_record.py", line 1162, in __import_type_support__
[odom_recorder-1] module = import_type_support('odom_interface')
[odom_recorder-1] File "/opt/ros/foxy/lib/python3.8/site-packages/rosidl_generator_py/import_type_support_impl.py", line 48, in import_type_support
[odom_recorder-1] raise UnsupportedTypeSupport(pkg_name)
[odom_recorder-1] rosidl_generator_py.import_type_support_impl.UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'odom_interface'
[odom_recorder-1] Exception ignored in: <function ActionServer.__del__ at 0x7f0ab951e790>
[odom_recorder-1] File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/action/server.py", line 633, in __del__
[odom_recorder-1] self.destroy()
[odom_recorder-1] File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/action/server.py", line 620, in destroy
[odom_recorder-1] if self._handle is None:
[odom_recorder-1] AttributeError: 'ActionServer' object has no attribute '_handle'
[ERROR] [odom_recorder-1]: process has died [pid 5393, exit code 1, cmd '/home/user/ros2_ws/install/wall_follower/lib/wall_follower/odom_recorder --ros-args'].
I have created a custom interface called odom_interface.
CMakeLists.txt:
cmake_minimum_required(VERSION 3.5)
project(odom_interface)
# Default to C99
if(NOT CMAKE_C_STANDARD)
set(CMAKE_C_STANDARD 99)
endif()
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
set(CMAKE_CXX_STANDARD 14)
endif()
endif()
# find dependencies
find_package(rclcpp REQUIRED)
find_package(std_msgs REQUIRED)
find_package(action_msgs REQUIRED)
find_package(geometry_msgs REQUIRED)
find_package(rosidl_default_generators REQUIRED)
if(BUILD_TESTING)
endif()
rosidl_generate_interfaces(${PROJECT_NAME}
"action/OdomRecord.action"
ament_package()
package.xml:
<?xml version="1.0"?>
<package format="3">
<name>odom_interface</name>
<version>0.0.0</version>
<buildtool_depend>ament_cmake</buildtool_depend>
<depend>rclcpp</depend>
<depend>std_msgs</depend>
<depend>action_msgs</depend>
<depend>geometry_msgs</depend>
<build_depend>rosidl_default_generators</build_depend>
<exec_depend>rosidl_default_runtime</exec_depend>
<member_of_group>rosidl_interface_packages</member_of_group>
<test_depend>ament_lint_auto</test_depend>
<test_depend>ament_lint_common</test_depend>
<export>
<build_type>ament_cmake</build_type>
</export>
</package>
odom_recorder.py:
import rclpy
from rclpy.action import ActionServer
from rclpy.node import Node
from odom_interface.action import OdomRecord
from geometry_msgs.msg import Point32
from std_msgs.msg import Float64
import time
class OdomActionServer(Node):
super().__init__('odom_action_server')
self.distance_publisher = self.create_publisher(Float64, 'total_distance', 10)
self.subscriber = self.create_subscription(Odometry, '/odom', self.odom_callback, QoSProfile(depth=10, reliability=ReliabilityPolicy.RELIABLE))
self.execute_goal = False
self.stored_init_meas = False
self.first_odom = Point32()
self.last_odom = Point32()
self.odom_record = []
self.total_distance = 0.0
self.last_x = 0.0
self.last_y = 0.0
def odom_callback(self, msg):
if self.execute_goal:
self.last_odom.x = msg.pose.pose.position.x
self.last_odom.y = msg.pose.pose.position.y
self.last_odom.z = msg.pose.pose.orientation.z
if not self.stored_init_meas:
self.first_odom.x = self.last_odom.x
self.first_odom.y = self.last_odom.y
self.first_odom.z = self.last_odom.z
self.get_logger().info(f'Initial measurement: {self.first_odom}')
self.odom_record.append(Point(x=self.first_odom.x, y=self.first_odom.y, z=0)) # Append the first_odom to the record
self.stored_init_meas = True
self.odom_record.append(Point(x=self.last_odom.x, y=self.last_odom.y, z=0)) # Append the current last_odom to the record
# Check if the robot has returned to the initial position
dist_to_start = ((self.last_odom.x - self.first_odom.x) ** 2 + (self.last_odom.y - self.first_odom.y) ** 2) ** 0.5
if dist_to_start < 0.05: # 5 cm
self.get_logger().info('Robot has returned to the initial position.')
self.set_result()
def execute_callback(self, goal_handle):
self.get_logger().info('Executing goal...')
self.execute_goal = True
self.first_odom.x = 0.0
self.first_odom.y = 0.0
self.first_odom.z = 0.0
self.last_odom.x = 0.0
self.last_odom.y = 0.0
self.last_odom.z = 0.0
self.odom_record = [] # Reset the odom_record list
# Create a timer to periodically publish feedback
self.timer = self.create_timer(1.0, lambda: self.publish_feedback(goal_handle))
def publish_feedback(self, goal_handle):
if len(self.odom_record) >= 2:
self.last_x = self.odom_record[-2].x
self.last_y = self.odom_record[-2].y
dist_p1_p2 = ((self.last_odom.x - self.last_x) ** 2 + (self.last_odom.y - self.last_y) ** 2) ** 0.5
self.total_distance += dist_p1_p2
feedback_msg = OdomRecord.Feedback()
feedback_msg.current_total = self.total_distance
goal_handle.publish_feedback(feedback_msg)
self.distance_publisher.publish(Float64(data=self.total_distance))
def set_result(self):
result = OdomRecord.Result()
result.list_of_odoms = self.odom_record
self._action_server.set_succeeded(result)
self.get_logger().info('Action succeeded. Total distance traveled: {0}'.format(self.total_distance))
def main(args=None):
rclpy.init(args=args)
# Create a MultiThreadedExecutor
executor = MultiThreadedExecutor(num_threads=4)
# adding node to executor
executor.add_node(odom_action_server)
try:
# spin the executor
executor.spin()
finally:
executor.shutdown()
odom_action_server.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main
Could someone give me some guidance on how to address this error?
Thank you.
