Hi
I just finished my action quiz and something happened. The server and client work correctly, but when I try to create the client through commands, it doesn’t work, what’s more, my meta variable “seconds” doesn’t even appear when I press [TAB] + [TAB].
user:~$ ros2 action send_goal -f /distance_as actions_quiz_msg/action/Distance
.__bashrc .config/ .ros/
.bash_aliases .gazebo/ .rviz/
.bashrc .history .sdformat/
.bashrc_bridge .ignition/ .sudo_as_admin_successful
.bashrc_ros1 .labelImg/ .theia/
.bashrc_ros2 .npmrc .yarn/
.cache/ .py3venv ros2_ws/
.catkin_ws_python3 .pylintrc
.clangd .python3_ws
And when I try to send feedback is similar, this is the message that appears.
user:~$ ros2 action send_goal -f /distance_as actions_quiz_msg/action/Distance "{seconds: 10}"
The passed action type is invalid
Everything works well except the command
That’s my Distance.action
# goal
int32 seconds
# result
bool status
float64 total_dist
# feedback
float64 current_dist
Some advice?
Hi @Voltedge ,
The general form of command to perform an action in ROS2 is like:
ros2 action send_goal --feedback <action_server_name> <action_interface_type> <action_goal_data>
(-f is same as --feedback, I use the longer version)
TAB+TAB only works when all the arguments till the cursor position where you hit TAB+TAB are correct. If one of the previous arguments are wrong, TAB+TAB will not work.
If the interface data is not showing up, the only possible reason, I believe, would be that the action interface is not compiled properly.
Does the action interface show up when you do ros2 interface list ?
If it does not, then the action command will not work.
Build the custom action message properly and then try the action command again.
That should fix the problem.
EDIT: Also make sure that you source your install directory from the terminal you call the action. Not sourcing will also not produce the action interface data for TAB+TAB autocompletion.
Hi @girishkumar.kannan
Is that okay? action_quiz_msg appears con actions, services and my install has a actions_quiz_msg package.
ros2 interface list
Another try with [TAB] + [TAB]
--feedback -f /distance_as /move_robot_as
user:~$ ros2 action send_goal --feedback
--feedback -f /distance_as /move_robot_asuser:~$ ros2 action send_goal --feedback
user:~$ ros2 action send_goal --feedback /distance_as actions_quiz_msg/action/Distance
.clangd .python3_ws
user:~$ ros2 action send_goal --feedback /distance_as actions_quiz_msg/action/Distance "{seconds:10}"
The TAB+TAB just doesn´t work with action_goal_data
user:~/ros2_ws$ colcon build --packages-select actions_quiz_msg
Starting >>> actions_quiz_msg
Finished <<< actions_quiz_msg [0.46s]
Summary: 1 package finished [0.66s]
Hi @Voltedge ,
Did you do source install/setup.bash (from ~/ros2_ws) before calling
ros2 action send_goal ...?
– Girish
Yes.
user:~/ros2_ws$ source install/setup.bash
user:~/ros2_ws$ ros2 action send_goal --feedback /distance_as actions_quiz_msg/action/Distance "{seconds: 10}"
user:~/ros2_ws$
Hi @Voltedge ,
Ok. That is so strange! Try these step by step:
Close all programs.
Restart all the four webshells by clicking on the red X button on each tab.
Delete your build, install and log folders
Rebuild your packages using
cd ~/ros2_ws
colcon build && source install/setup.bash
Start the action server in webshell 1 if not already running
Source your install directory again and call action from webshell 2.
This time it should work. If it does not then let me know!
I attach the shells, I deleted the packages install, log and build by hand
SHELL 1:
[0.708s] WARNING:colcon.colcon_ros.prefix_path.ament:The path '/home/user/ros2_ws/install/services_quiz' in the environment variable AMENT_PREFIX_PATH doesn't exist
[0.708s] WARNING:colcon.colcon_ros.prefix_path.ament:The path '/home/user/ros2_ws/install/services_quiz_srv' in the environment variable AMENT_PREFIX_PATH doesn't exist
[0.708s] WARNING:colcon.colcon_ros.prefix_path.ament:The path '/home/user/ros2_ws/install/actions_quiz' in the environment variable AMENT_PREFIX_PATH doesn't exist
[0.708s] WARNING:colcon.colcon_ros.prefix_path.ament:The path '/home/user/ros2_ws/install/radio_shack' in the environment variable AMENT_PREFIX_PATH doesn't exist
[0.709s] WARNING:colcon.colcon_ros.prefix_path.ament:The path '/home/user/ros2_ws/install/my_action_server' in the environment variable AMENT_PREFIX_PATH doesn't exist
[0.709s] WARNING:colcon.colcon_ros.prefix_path.ament:The path '/home/user/ros2_ws/install/my_action_client' in the environment variable AMENT_PREFIX_PATH doesn't exist
[0.709s] WARNING:colcon.colcon_ros.prefix_path.ament:The path '/home/user/ros2_ws/install/actions_quiz_msg' in the environment variable AMENT_PREFIX_PATH doesn't exist
[0.709s] WARNING:colcon.colcon_ros.prefix_path.catkin:The path '/home/user/ros2_ws/install/services_quiz' in the environment variable CMAKE_PREFIX_PATH doesn't exist
[0.709s] WARNING:colcon.colcon_ros.prefix_path.catkin:The path '/home/user/ros2_ws/install/services_quiz_srv' in the environment variable CMAKE_PREFIX_PATH doesn't exist
[0.709s] WARNING:colcon.colcon_ros.prefix_path.catkin:The path '/home/user/ros2_ws/install/actions_quiz' in the environment variable CMAKE_PREFIX_PATH doesn't exist
[0.710s] WARNING:colcon.colcon_ros.prefix_path.catkin:The path '/home/user/ros2_ws/install/radio_shack' in the environment variable CMAKE_PREFIX_PATH doesn't exist
[0.710s] WARNING:colcon.colcon_ros.prefix_path.catkin:The path '/home/user/ros2_ws/install/my_action_server' in the environment variable CMAKE_PREFIX_PATH doesn't exist
[0.710s] WARNING:colcon.colcon_ros.prefix_path.catkin:The path '/home/user/ros2_ws/install/my_action_client' in the environment variable CMAKE_PREFIX_PATH doesn't exist
[0.710s] WARNING:colcon.colcon_ros.prefix_path.catkin:The path '/home/user/ros2_ws/install/actions_quiz_msg' in the environment variable CMAKE_PREFIX_PATH doesn't exist
Starting >>> radio_shack
Starting >>> services_quiz_srv
Starting >>> my_action_client
Starting >>> my_action_server
Finished <<< my_action_client [27.0s]
Finished <<< my_action_server [31.6s]
Finished <<< radio_shack [33.7s]
Finished <<< services_quiz_srv [34.4s]
Finished <<< actions_quiz_msg [34.8s]
Finished <<< services_quiz [18.5s]
Finished <<< actions_quiz [30.1s]
Summary: 7 packages finished [1min 5s]
user:~/ros2_ws$ ros2 launch actions_quiz actions_quiz_server.launch.py
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2023-01-12-18-35-19-738510-4_xterm-7965
[INFO] [action_server-1]: process started with pid [7966]
SHELL 2:
user:~$ ros2 action list
/distance_as
/move_robot_as
user:~$ ros2 action send_goal /distance_as actions_quiz_msg/action/Distance
.__bashrc .clangd .python3_ws
.bash_aliases .config/ .ros/
.bash_history .gazebo/ .rviz/
user:~$ ros2 action send_goal /distance_as actions_quiz_msg/action/Distance "{seconds: 10}"
Still not working
Hi @Voltedge ,
You can ignore the warnings in shell 1.
It seems you did not source install directory on shell 2. But if you did source and you still get this error, then you should probably close the course and reopen after sometime, like after 30 minutes. Perhaps things would be back to normal then.
Sorry I could not help much with this particular case.
I was waiting until now and still not working
Thanks for your advices.
I guess I communicate with The Construct team?
Hi @Voltedge ,
I think this would be your next step!
Hello @Voltedge ,
Just tested this and it’s working of for me, with autocompletion and everything:
Are you still having this issue?
Hi @albertoezquerro
Not anymore! It works, thanks!
