ROS2 Basics: Project on Services
Hi all,
I am working on the second part of ROS2 “real robot” wall-following project.
Following is the intended behavior:
  1. Run wall_finder node (service server) that aligns the robot to the nearest wall, approaches to ~0.30 m, rotates so the wall is on the robot’s right.
  2. Run wall_follower node (client) that first calls the find_wall service and only after the service completes starts publishing for right-wall following.
Following is my issue (with the FastBot in Small city lab):
If I launch wall_finder (server) first: it starts and shows “server ready”.
When I launch wall_follower (client): it receives LaserScan continuously and prints scan values for ranges, but the robot does not move at all.
Here’s the part that I don’t understand: as soon as I press Ctrl+C to stop the client process, the robot suddenly starts moving (it looks like the server-side wall-finding motion begins right after the client exits).
In simulation, everything runs correctly (client calls service, server moves robot, client then follows wall) but on the real robot the behavior is strange and I suspect my service-client/executor behavior (or timing/discovery) of causing some sort of a block.
What could cause the real robot to only move after the client is killed, even though the service server is “ready” and topics appear correct?
I am pasting the relevant structure from my wall_follower node (client). I’m using MultiThreadedExecutor(num_threads=4) and ReentrantCallbackGroup .
Blockquote
  1. Setup in __init__
  • Create /cmd_vel publisher
  • Create service client /find_wall
  • Create a timer to try calling the service (non-blocking)
  • Create /scan subscriber
  • Create control timer (wall-following loop)
  1. Service call is done through a timer
  • try_call_find_wall() runs every 0.5 sec:
    • If not aligned and not already waiting for a future → calls call_async()
    • Adds a done-callback to set self.aligned=True when the server finishes
  1. Control callback is blocked until service finishes
  • control_callback() publishes zero velocities until self.aligned=True
Here is the exact relevant structure (same as my code):
  • In init ():
    • self.srv_client = create_client(FindWall, ‘/find_wall’)
    • self.aligned = False
    • self.req = FindWall.Request()
    • self.future = None
    • self.service_call_timer = create_timer(0.5, try_call_find_wall)
    • create_subscription(‘/scan’, scan_callback)
    • create_timer(0.5, control_callback)
  • try_call_find_wall():
    • if aligned: return
    • if future exists and not done: return
    • future = srv_client.call_async(req)
    • future.add_done_callback(find_wall_done_callback)
  • find_wall_done_callback(future):
    • response = future.result()
    • if response.wallfound: aligned=True
  • scan_callback(scan_msg):
    • compute min window distances for left/front/right
    • print “Scan | L:… F:… R:…”
  • control_callback():
    • if not aligned:
      publish 0 cmd_vel and return
    • else:
      wall follow logic publishes cmd_vel
Blockquote
Any advise would be helpful!
Thank you!
Hello @ninadmehta34 ,
It seems the issue is with the fact that all your callbacks are in the same group. So even if you have a multithreaded executor if the callback group is the same and it is one assigned by default. No proper multi-threading occurs.
@takavarasha thank you for getting back to me.
I tried putting them in separate callback groups as well. That didn’t change the behavior at all.
Following is my code:
Blockquote
    self.cb_service1 = ReentrantCallbackGroup()
    self.cb_service2 = ReentrantCallbackGroup()
    self.cb_scan    = ReentrantCallbackGroup()
    self.cb_ctrl    = ReentrantCallbackGroup()
    # self.callback_group = ReentrantCallbackGroup()
    # Create the client
    self.srv_client = self.create_client(FindWall, 'find_wall', callback_group=self.cb_service1)
    self.service_call_timer = self.create_timer(
        0.5, self.try_call_find_wall, callback_group = self.cb_service2
    self.scan_sub = self.create_subscription(LaserScan, "/scan", self.scan_callback,
                                             QoSProfile(depth=10, reliability=ReliabilityPolicy.RELIABLE), callback_group=self.cb_scan)
    self.get_logger().info("Initialized /scan Subscriber")
    self.control_timer = self.create_timer(timer_period_sec=0.500,
                                           callback=self.control_callback,
                                           callback_group=self.cb_ctrl)
Blockquote
Following is the code in def main():
Blockquote
def main(args=None):
#initialize ROS2 node
rclpy.init(args=args)
#create an instance of the wall follower class
wall_follower = WallFollower()
#create a multithread executor
executor = MultiThreadedExecutor(num_threads=4)
#add the wall follower node to the executor
executor.add_node(wall_follower)
try:
    #spin the executor to handle callbacks
    executor.spin()
except:
    pass
finally:
    # indicate wall follower node termination
    wall_follower.get_logger().info("Terminating Wall Follower...")
    #stop the robot
    wall_follower.twist_cmd.linear.x = wall_follower.lin_vel_zero
    wall_follower.twist_cmd.angular.z = wall_follower.ang_vel_zero
    #publish the twist command
    wall_follower.publish_twist_cmd()
    wall_follower.get_logger().info("Wall Follower Terminated !")
#shutdown the executor when spin completes
executor.shutdown()
#destroy the wall follower node
wall_follower.destroy_node()
#shutdown ROS2 node when spin completes
rclpy.shutdown()
return None
if name == “main”:
main()
Blockquote
Would putting the rest of the client code here help? Looking forward to your response.
Thank you!
Ninad Mehta
Hi @ninadmehta34,
Yes, please share. we need to verify where the /cmd_vel publishing is happening. If your service callback is publishing /cmd_vel commands while waiting for the alignment to complete, it will block and never return a response to the client.
The correct pattern is:
The service callback should only return a response (True/False) immediately
The /cmd_vel publishing should happen in a separate timer callback, not inside the service callback
@takavarasha
I think my /cmd_vel publishing is happening inside a separate timer callback.
But following is my code:
#! /usr/bin/python3
#imports & rclpy imports
import rclpy
from rclpy.node import Node
from rclpy.executors import MultiThreadedExecutor # multithreaded executor
from rclpy.callback_groups import ReentrantCallbackGroup #reentrant callback
#ros2 interfaces
#standard imports
import math
#import the service
from custom_interfaces.srv import FindWall
#define wall follower class as a subclass of node class
class WallFollower(Node):
    #class constructor
        super().__init__("Wall_follower")
        self.get_logger().info("Initializing Wall Follower...")
        #declare and initialize cmd_vel publisher
        self.cmd_vel_pub = self.create_publisher(Twist,"/cmd_vel",10)
        self.get_logger().info("Initialized /cmd_vel Publisher")
        #declare and initialize callback group
        # Create the client
        self.aligned = False  # flag to hold the wall-following behavior
        self.future = None
        #declare and initialize scan subscriber
        #declare and initialize control timer callback
        self.get_logger().info("Initialized Control Timer")
        self.get_logger().info("Wall Follower Initialized")
        return None
    #class destructor
    def __del__(self):
        return None
    #define and initialize class variables
    #robot_radius = 0.10  # m
    side_threshold_min = 0.20   # m gap
    side_threshold_max = 0.30    # m gap
    front_threshold = 0.50        # m gap
    pi = 3.141592654
    pi_inv = 0.318309
    ignore_iterations = 5
    iterations_count = 0
    #process variables
    wall_found = False
    side_chosen = "right"
    lin_vel_zero = 0.000
    lin_vel_slow = 0.100
    lin_vel_fast = 0.250
    ang_vel_zero = 0.000
    ang_vel_slow = 0.050
    ang_vel_fast = 0.500
    ang_vel_mult = 1.250
    #velocity publisher variables
    twist_cmd = Twist()
    #scan subscriber variables
    scan_info_done = False
    scan_angle_min = 0.0
    scan_angle_max = 0.0
    scan_angle_inc = 0.0
    scan_range_min = 0.0
    scan_range_max = 0.0
    scan_right_range = 0.0
    scan_front_range = 0.0
    scan_left_range = 0.0
    scan_angle_range = 0
    scan_ranges_size = 0
    scan_right_index = 0
    scan_left_index = 0
    # SERVICE CLIENT METHODS
    def try_call_find_wall(self):
        #already aligned or waiting for response
        if self.aligned or (self.future is not None and not self.future.done()):
            return
        self.get_logger().info("Calling 'find wall' service")
        self.future = self.srv_client.call_async(self.req)
        self.future.add_done_callback(self.find_wall_done_callback)
    def find_wall_done_callback(self, future):
        try:
                self.get_logger().info('Success: Wall found and aligned!')
                self.aligned = True
            else:
                self.get_logger().warn('Service finished but wallfound is False.')
        except Exception as e:
            self.get_logger().error(f'Service call failed: {e}')
    # LASER SCAN
    def scan_callback(self, scan_msg):
        if not self.scan_info_done:
            self.scan_angle_min = scan_msg.angle_min
            self.scan_angle_inc = scan_msg.angle_increment
            self.scan_ranges_size = len(scan_msg.ranges)
            self.scan_range_min = scan_msg.range_min
            self.scan_range_max = scan_msg.range_max
            self.scan_info_done = True
            self.get_logger().info("Scan initialized")
            return
        def get_min_range(target_angle_rad, window_deg=15):
            window_rad = math.radians(window_deg)
            min_dist = self.scan_range_max
            for i, r in enumerate(scan_msg.ranges):
                if math.isinf(r) or math.isnan(r):
                    continue
                angle = self.scan_angle_min + i * self.scan_angle_inc
                # normalize angle to [-pi, pi]
                angle = (angle + math.pi) % (2 * math.pi) - math.pi
                if abs(angle - target_angle_rad) <= window_rad:
                    if r < min_dist:
                        min_dist = r
            return min_dist
        self.scan_front_range = get_min_range(0.0)
        self.scan_right_range = get_min_range(-math.pi / 2)
        self.scan_left_range  = get_min_range(+math.pi / 2)
            f"Scan | L:{self.scan_left_range:.2f} "
            f"F:{self.scan_front_range:.2f} "
            f"R:{self.scan_right_range:.2f}"
    # CONTROL
    def control_callback(self):
        # Block wall following until service is complete
        if not self.aligned:
            self.twist_cmd.linear.x = 0.0
            self.twist_cmd.angular.z = 0.0
            self.publish_twist_cmd()
            return
        # Safety: wait for scan to initialize
            return
        # 1. FRONT WALL AVOIDANCE
        if self.scan_front_range < self.front_threshold:
            self.twist_cmd.linear.x = self.lin_vel_slow
            if self.side_chosen == "right":
                # turn LEFT to avoid front wall
                self.twist_cmd.angular.z = self.ang_vel_fast
            elif self.side_chosen == "left":
                # turn RIGHT to avoid front wall
                self.twist_cmd.angular.z = -self.ang_vel_fast
            return
        # 2. SIDE WALL FOLLOWING
            side_dist = self.scan_right_range
            if side_dist < self.side_threshold_min:
                # too close → steer away (LEFT)
                self.twist_cmd.linear.x = self.lin_vel_fast
                self.twist_cmd.angular.z = self.ang_vel_slow
            elif side_dist > self.side_threshold_max:
                # too far → steer towards wall (RIGHT)
                self.twist_cmd.angular.z = -self.ang_vel_slow
            else:
            side_dist = self.scan_left_range
                # too close → steer away (RIGHT)
                # too far → steer towards wall (LEFT)
            else:
    def publish_twist_cmd(self):
        # Clamp linear velocity
        if self.twist_cmd.linear.x > 0.150:
            self.twist_cmd.linear.x = 0.150
        elif self.twist_cmd.linear.x < 0.0:
        # Clamp angular velocity
        if self.twist_cmd.angular.z > 0.450:
            self.twist_cmd.angular.z = 0.450
        elif self.twist_cmd.angular.z < -0.450:
            self.twist_cmd.angular.z = -0.450
        self.cmd_vel_pub.publish(self.twist_cmd)
        return None
    try:
        executor.spin()
    except:
        pass
    finally:
        #stop the robot
    executor.shutdown()
    rclpy.shutdown()
    return None
if __name__ == "__main__":
    main()
Okay, I see… can you share the wall_finder script as well please
Yes
#! /usr/bin/python3
import math
import rclpy
import time # Added for the loop delay
class WallFinder(Node):
        super().__init__("Wall_Finder_test")
        self.get_logger().info("Initializing wall_finder")
        #reentrant group
        self.reentrant_group_1 = ReentrantCallbackGroup()
        self.reentrant_group_2 = ReentrantCallbackGroup()
        self.scan_sub = self.create_subscription(LaserScan, "/scan", self.scan_callback, 10, callback_group=self.reentrant_group_1)
        # self.control_timer = self.create_timer(0.1, self.control_callback)
        self.srv = self.create_service(FindWall, 'find_wall', self.find_wall_callback, callback_group=self.reentrant_group_2)
        self.scan_ready = False
        self.latest_scan = None
        #going by stages: face_wall, approach, rotate_right, done
        self.stage = "face_wall"
        self.distance_from_wall = 0.3 # meters
        self.distance_from_wall_tolerance = 0.01
        self.angle_tolerance_rad = math.radians(2.0) #stop when within +-5
        self.turn_speed = 0.2
        self.linear_vel = 0.05
        self.twist_cmd = Twist()
        self.get_logger().info("Find wall service ready...")
    #define scan callback to get the ranges and get the minimum range out of all
        # Always keep the latest scan
        self.latest_scan = scan_msg
        self.scan_ready = True
        if not self.scan_ready:
    def find_wall_callback(self, request, response):
        self.get_logger().info("Service Started: Finding wall...")
        while self.stage != "done":
            if not self.scan_ready or self.latest_scan is None:
                self.get_logger().info("Waiting for scan...")
                time.sleep(0.1)
                continue
            scan = self.latest_scan
            #below was a sanity check for what index the right side of robot is at.
            # for idx in [0, 180, 270, 360, 540, 719]:
            #     ang = scan.angle_min + idx*scan.angle_increment
            #     self.get_logger().info(f"idx {idx} -> {math.degrees(ang):.1f} deg")
            # 1. Find global minimum valid range and its index
            best_range = float('inf')
            best_index = None
            for idex, rnge in enumerate(scan.ranges):
                if math.isinf(rnge) or math.isnan(rnge):
                    continue
                # Below is to skip readings that are likely the robot's own body (noise)
                # Simulation doesn't have this, but real robot might.
                if rnge < 0.15:
                    continue
                if rnge < best_range:
                    best_range = rnge
                    best_index = idex
            # Handle case where no wall is seen
            if best_index is None:
                self.get_logger().warn("No valid LaserScan ranges found beyond 0.15m.")
                self.publish_cmd(0.0, 0.0)
                time.sleep(0.1)
                continue
            best_angle = scan.angle_min + best_index * scan.angle_increment
            best_angle = (best_angle + math.pi) % (2 * math.pi) - math.pi # normalize [-pi, pi]
            #STAGE 1 Face the Wall
            if self.stage == "face_wall":
                # Check if the closest point is within our tolerance (e.g. 10 degrees)
                if abs(best_angle) <= self.angle_tolerance_rad:
                        f"STAGE 1 COMPLETE: Facing wall. Min={best_range:.2f}m angle={math.degrees(best_angle):.1f} deg"
                    self.stage = "approach"
                else:
                    # If best_angle is positive, wall is to our left -> turn left (positive speed)
                    # If best_angle is negative, wall is to our right -> turn right (negative speed)
                    angular_speed = self.turn_speed if best_angle > 0 else -self.turn_speed
                    self.publish_cmd(0.0, angular_speed)
            #Stage 2: Approach to 0.3 m
            elif self.stage == "approach":
                front_dist = scan.ranges[0]
                if math.isinf(front_dist) or math.isnan(front_dist):
                    self.get_logger().warn("Front distance invalid. Stopping.")
                    continue
                if front_dist > (self.distance_from_wall + self.distance_from_wall_tolerance):
                    self.publish_cmd(self.linear_vel, 0.0)
                else:
                    self.get_logger().info(f"Reached ~0.3m from wall. Front={front_dist:.2f}m")
                    self.stage = "rotate_right_align"
            # STAGE 3: rotate until wall is on right
            elif self.stage == "rotate_right_align":
                # Target for Right Side is -90 degrees (-1.57 radians)
                target_angle = -1.57
                angle_tolerance = math.radians(2.0)
                # Calculate how far we are from the target angle
                error = best_angle - target_angle
                if abs(error) < angle_tolerance:
                    self.stage = "done"
                    self.get_logger().info(f"Stage 3 Complete: Wall aligned at {math.degrees(best_angle):.1f} deg")
                else:
                    self.publish_cmd(0.0, self.turn_speed)
            time.sleep(0.05) # Prevent CPU hogging
            # Final Response
        response.wallfound = True
        self.get_logger().info("Service Finished: Wall Found and Aligned.")
        return response
    def publish_cmd(self, linear_vel, angular_speed):
        twist_cmd =Twist()
        twist_cmd.linear.x = float(linear_vel)
        twist_cmd.angular.z = float(angular_speed)
        self.cmd_vel_pub.publish(twist_cmd)
    find_wall_node=WallFinder()
    #Use multithread executor
    executor = MultiThreadedExecutor(num_threads=3)
    executor.add_node(find_wall_node)
    try:
        executor.spin()
    except KeyboardInterrupt:
        pass
    finally:
        find_wall_node.cmd_vel_pub.publish(Twist()) #stop robot on shutdown
        find_wall_node.destroy_node()
        rclpy.shutdown()
    main()
There is publishing of cmd_vel value in this… I think this require re-implementation. Otherwise, as it stands every case the involves the call to publish will cause the response line to be not reached until the callback is forced to exit.
You are right! I missed that the control callback keeps calling cmd_vel while my service server is also calling it to align it with the wall. I think what was happening was:
In the control_callback, “if not self.aligned” and “if not self.scan_info_done” were interfering with the server’s cmd_vel and eventually causing the robot to not move at all (this was the explanation I could come up with).
Remove cmd_vel from those two fixed the issue!
Thank you for the help @takavarasha. Its working fine now.
