I am getting this error when I want to echo the /counter topic
Same error pops up when I want to pub on the topic. Any idea what that might be?
Try with:
ros2 topic echo /counter std_msgs/Int32
And verify that the topic is available:
ros2 topic list
Found the issue, just needed to use a terminal with the /opt/ros/foxy/setup.bash sourced instead of the ros2_ws setup file sourced. Not sure if this was the root cause of the issue but works now.
thanks @mtorres for chipping in. Found the solution now.
