I have been completing the ROS2 in 5 days (Python) course. I am working on Part II of the Rosject, which involves making a Service Server and Client for the Find Wall behaviour.
I have implemented client functionality into the node and it successfully calls the Find Wall Server at startup. However, the Server never ends. I’m not sure if client.future.done() is needed here, but after completing it’s behaviour, the program never goes back to the wall-following behaviour. If i remove the Service related code, then it executes the wall-following behaviour correctly. Here are the two scripts
wall_following.py:
import rclpy
# import the ROS2 python libraries
from rclpy.node import Node
# import the LaserScan module from sensor_msgs interface
from std_srvs.srv import Empty
# import Quality of Service library, to set the correct profile and reliability to read sensor data.
class WallFollower(Node):
super().__init__('wall_follower')
self.dist_right = 0.0
self.dist_fwd = 0.0
self.laser_subscriber = self.create_subscription(
LaserScan, '/scan',
self.wall_dist,
QoSProfile(depth=10,
reliability=ReliabilityPolicy.RELIABLE))
self.move_pub_ = self.create_publisher(
Twist, 'cmd_vel', 10)
# Find Wall Behaviour
self.client = self.create_client(Empty, 'find_wall')
while not self.client.wait_for_service(timeout_sec=1.0):
self.get_logger().info('service not available, waiting again...')
self.req = Empty.Request()
timer_period = 0.5
self.timer = self.create_timer(timer_period, self.move)
def send_request(self):
self.client.future = self.client.call(self.req)
def wall_dist(self, msg):
# print the log info in the terminal
self.dist_right = msg.ranges[520]
self.dist_left = msg.ranges[180]
self.dist_fwd = msg.ranges[0]
self.all_dist = msg
# self.get_logger().info('Dist fwd: "%s"' % str(self.dist_fwd))
# self.get_logger().info('Dist to wall: "%s"' % str(self.dist_right))
# self.get_logger().info('Dist to left: "%s"' % str(self.dist_left))
def move(self):
cmd = Twist()
self.get_logger().info('Dist fwd YA MADFE IT HERE: "%s"' % str(self.dist_fwd))
if self.dist_fwd < 0.5:
cmd.angular.z = 0.35
cmd.linear.x = 0.01
elif self.dist_right > 0.3:
cmd.angular.z = -0.2
cmd.linear.x = 0.03
elif self.dist_right < 0.3 and self.dist_right > 0.2:
cmd.angular.z = 0.0
cmd.linear.x = 0.05
elif self.dist_right < 0.2:
cmd.angular.z = 0.2
cmd.linear.x = 0.03
self.move_pub_.publish(cmd)
def main(args=None):
rclpy.init(args=args)
wall_follower = WallFollower()
wall_follower.send_request()
rclpy.spin(wall_follower)
# Explicity destroy the node
wall_follower.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
And wall_finder.py:
import rclpy
from rclpy.callback_groups import ReentrantCallbackGroup
RIGHT = 520
LEFT = 180
FWD = 0
class WallFinder(Node):
super().__init__('wall_finder')
self.reentrant_group_1 = ReentrantCallbackGroup()
self.srv = self.create_service(Empty, 'find_wall', self.find_wall_callback, callback_group=self.reentrant_group_1)
self.dist_fwd = 0.0
LaserScan, '/scan',
self.wall_dist,
reliability=ReliabilityPolicy.RELIABLE), callback_group=self.reentrant_group_1)
self.move_order = "TURN 1"
self.dist_left = msg.ranges[LEFT]
self.dist_right = msg.ranges[RIGHT]
self.dist_fwd = msg.ranges[FWD]
self.all_dist = msg
def find_wall_callback(self, request, response):
cmd = Twist()
# response.success = True
while self.move_order != "FINISHED":
self.get_logger().info('MOVEMENT: "%s"' % str(self.move_order))
if self.move_order == "TURN 1":
index = self.all_dist.ranges.index(min(self.all_dist.ranges))
if index < 360:
cmd.angular.z = 0.2
elif index >= 360:
# turn right
if index == FWD:
cmd.angular.z = 0.0
self.move_order = "MOVE 1"
elif self.move_order == "MOVE 1":
if min(self.all_dist.ranges) > 0.305:
cmd.linear.x = 0.05
elif min(self.all_dist.ranges) <= 0.295:
cmd.linear.x = -0.05
else:
cmd.linear.x = 0.0
self.move_order = "TURN 2"
elif self.move_order == "TURN 2":
if index >= LEFT and index <= (LEFT+360):
else:
cmd.angular.z = 0.2
if index == RIGHT:
cmd.angular.z = 0.0
self.move_order = "FINISHED"
# response.success = False
# response.message = "Finished"
return response
wall_finder = WallFinder()
executor = MultiThreadedExecutor(num_threads=2)
executor.add_node(wall_finder)
try:
executor.spin()
finally:
wall_finder.destroy_node()
executor.shutdown()
main()
Thank you for your time, let me know if you have any questions or need any more information!
Cheers
