Hello, I have gradebot failed due to can’t find /turn. When I ran service server, I can find the ros2 service list with name /turn. Could you please help me with this?
Hello @junjng9 ,
Everything seems to be fine from a first look. Could you try sending it again for grading? Maybe there was some isolated issue in the grader side the 1st time you sent it.
Hello @junjng9 ,
I’ve been doing some tests with your files, and here’s what I’ve found.
- First of all, I’ve tried correcting the quiz and it detected the service correctly:
As you can see, it fails in a later stage, when trying to launch the client, because that is not working:
- I found you had some compilation files inside your src folder, which is not correct:
I have removed them, as this could introduce errors. ALWAYS compile in the root of the workspace (ros2_ws folder).
Try correcting the error with the service client and let me know how it goes.
