I am working on the ROS2 in 5 days (Python) course Unit 3 about Topics and I have issues with the following command:
ros2 topic echo /cmd_vel
The terminal then outputs the following:
File "/opt/ros/foxy/bin/ros2", line 11, in <module>
load_entry_point('ros2cli==0.9.7', 'console_scripts', 'ros2')()
File "/opt/ros/foxy/lib/python3.8/site-packages/ros2cli/cli.py", line 67, in main
rc = extension.main(parser=parser, args=args)
File "/opt/ros/foxy/lib/python3.8/site-packages/ros2topic/command/topic.py", line 41, in main
return extension.main(args=args)
File "/opt/ros/foxy/lib/python3.8/site-packages/ros2topic/verb/echo.py", line 81, in main
return main(args)
File "/opt/ros/foxy/lib/python3.8/site-packages/ros2topic/verb/echo.py", line 95, in main
message_type = get_msg_class(node, args.topic_name, include_hidden_topics=True)
File "/opt/ros/foxy/lib/python3.8/site-packages/ros2topic/api/__init__.py", line 88, in get_msg_class
msg_class = _get_msg_class(node, topic, include_hidden_topics)
File "/opt/ros/foxy/lib/python3.8/site-packages/ros2topic/api/__init__.py", line 133, in _get_msg_class
return get_message(message_type)
File "/opt/ros/foxy/lib/python3.8/site-packages/rosidl_runtime_py/utilities.py", line 30, in get_message
raise ValueError("Expected the full name of a message, got '{}'".format(identifier))
ValueError: Expected the full name of a message, got 'geometry_msgs/msg/Twist'
I have initiated the ROS2 environment with:
I receive similar errors when I try to echo another topic.
And when I try to publish into a topic with:
ros2 topic pub --once /cmd_vel geometry_msgs/msg/Twist "{linear: {x: 0.1, y: 0.0, z: 0.0}, angular: {x: 0.0, y: 0.0, z: 1.0}}"
I receive the following output:
File "/opt/ros/foxy/lib/python3.8/site-packages/ros2topic/verb/pub.py", line 93, in main
return main(args)
File "/opt/ros/foxy/lib/python3.8/site-packages/ros2topic/verb/pub.py", line 103, in main
return publisher(
File "/opt/ros/foxy/lib/python3.8/site-packages/ros2topic/verb/pub.py", line 125, in publisher
msg_module = get_message(message_type)
Am I doing something wrong or why doesn’t it work? I would expect that it simply echoes the topic content rsp. publish something into the topic.
