I hope you are good. I am getting the error in the picture below for rosc++ in 5 days course. It doesnt recognize ros for some reason so i am unable to launch the simple.cpp script. Please help me solve this problem, thank you.
Hi Elena,
Try with
#include "ros/ros.h"
Also make sure that you added the script as an executable to CMakeLists.txt
Are you getting any errors when you try to launch the script? You may ignore those errors in the IDE if they are not related to the errors you get (if any) while running the script.
The IDE ‘header file not found’ error is a known issue and we are looking into it.
okay i would try this, thank you.
The errors are not necessarily related. What errors are you getting?
Hi @Yelaina ,
we’ve just solved the autocompletion for C++ issue.
Now it should work properly.
It may happen that the IDE may not autocomplete just instantly because it may be parsing the include files, but after some seconds it should work fine.
Thanks for reporting it.
Thank you @ralves. I have tried launching the program again and got the below error.
user:~$ roslaunch my_package my_package_launch_file.launch
… logging to /home/user/.ros/log/143d52ea-0a8d-11ec-9333-0242ac170007/roslaunch-1_xterm-1599.log
Press Ctrl-C to interrupt
started roslaunch server http://1_xterm:37187/
PARAMETERS
NODES
ObiWan (my_package/simple.cpp)
RLException: Unable to launch [ObiWan-1].
If it is a script, you may be missing a ‘#!’ declaration at the top.
[ObiWan-1] killing on exit
The error simply means your node is still not set up properly. Please ensure you:
CMakeLists.txt
and package.xml
. Please double-check for correct spelling and case (names are case-sensitive).cd ~/catkin_ws
catkin_make
cd ~/catkin_ws
source devel/setup.bash
