Rosject - automatic window reopening - bash history
When I run my rosject, I have to open everything (editor, terminals, notebooks) and the bash history does not contain my commands.
I have only two rosjects, ros basic python 5 days and ros2 navigation.
This is very boring and a tedious task to open everything after every run.
I tried the Save function, but did not helped.
Is this a missing feature or did I make something in the wrong way?
Thank you in advance
Hi Peter,
you are completely right. The system should store both the bash history and the full configuration of the screen as you left it.
I’m adding this to the list of improvements. We are going to add those features along May.
Thank you very much for letting us know how much this bothers you. Please, do not hesitate to tell us more about any other things you would like to have.
Just for your knowledge, we are at present working on adding persistent installation of libraries, so you can install packages and libraries in your rosject and they will stay on future openings of the project. That is a major change and difficult to implement. So once we have this done, we will go with your request.
Thank you!
