Rosject - Mapping section rviz and map_server
Hi community,
I am working on the Mapping section of the Rosject. I found that if I use a single launch file to launch map_server and rviz2, rviz2 will not receive the map topic from map_server. I believe it is because the map_server publishes the map topic before the rviz2 has launched. Because if I call the load map service, the rviz2 can show the map correctly.
Is there any method to solve this or should I write them in separate launch files? Below is my launch file.
import os
import launch.actions
import launch_ros.actions
    rviz_config_dir = <path-to-rviz-config>
    map_file = <path-to-my-map>
    return LaunchDescription([
        Node(
            package='nav2_map_server',
            node_executable='map_server',
            node_name='map_server',
            output='screen',
                        {'yaml_filename':map_file}
        Node(
            package='rviz2',
            node_executable='rviz2',
            node_name='rviz2',
            arguments=['-d', rviz_config_dir],
            parameters=[{'use_sim_time': True}],
            output='screen'
        Node(
            node_executable='lifecycle_manager',
            node_name='lifecycle_manager_localization',
            output='screen',
                        {'autostart': True},
                        {'node_names': ['map_server']}])
Thanks,
Alan
Hello @alan0428a ,
Have you tried unchecking/checking again the Map Display checkbox in Rviz2? I’ve encountered similar issues with RViz2 that could be solved just by doing that.
Hi @albertoezquerro ,
Thanks for the reply. Unfortunately, checking/unchecking the Map Display doesn’t work for me. It does not show the map.
Hello @alan0428a ,
Having a look to your launch file, I can see that you didn’t specify the path to your files (rviz configuration and map):
Probably here is the problem.
