Hello. I’m doing the ros in 5 days rosject - and am at the Actions part.
Im trying to test the list_of_odoms, but my code isnt running. it returns an error when i set the result as succeeded. i tried to subscribe to the odometry and append it to the result/list of odoms.
redord_odom.py
from turtlebot3_move.msg import OdomRecordAction, OdomRecordFeedback, OdomRecordResult
from turtlebot3_move.msg import OdomRecordAction, OdomRecordActionFeedback, OdomRecordActionResult
import actionlib
import time
class Robot(object):
_feedback = OdomRecordFeedback()
self._as = actionlib.SimpleActionServer('/record_odom', OdomRecordAction, self.execute_callback, False)
self._as.start()
self.ctrl_c = False
self.rospy = rospy
self._result = OdomRecordResult()
def sub_cb(self, msg):
return msg.pose.pose
def execute_callback(self, goal):
success = True
print('action server called')
self.sub = rospy.Subscriber('/odom', Odometry, self.sub_cb, queue_size = 1)
for i in range(0, 10):
self._result.list_of_odoms.append(self.sub_cb)
time.sleep(1)
if success:
rospy.loginfo('succeeded')
if __name__ == '__main__':
rospy.init_node('record_odom')
Robot()
rospy.spin()
shell:
^Cuser:~$ rosrun turtlebot3_move record_odom.py
[INFO] [1633178800.041950, 1743.076000]: succeeded
[ERROR] [1633178800.241541, 1743.181000]: Exception in your execute callback: 'function' object has no attribute 'x'
File "/home/simulations/public_sim_ws/src/all/actionlib/actionlib/src/actionlib/simple_action_server.py", line 289, in executeLoop
self.execute_callback(goal)
File "/home/user/catkin_ws/src/turtlebot3_move/scripts/record_odom.py", line 37, in execute_callback
File "/home/simulations/public_sim_ws/src/all/actionlib/actionlib/src/actionlib/simple_action_server.py", line 162, in set_succeeded
self.current_goal.set_succeeded(result, text)
File "/home/simulations/public_sim_ws/src/all/actionlib/actionlib/src/actionlib/server_goal_handle.py", line 195, in set_succeeded
self.action_server.publish_result(self.status_tracker.status, result)
File "/home/simulations/public_sim_ws/src/all/actionlib/actionlib/src/actionlib/action_server.py", line 182, in publish_result
self.result_pub.publish(ar)
File "/opt/ros/noetic/lib/python3/dist-packages/rospy/topics.py", line 882, in publish
self.impl.publish(data)
File "/opt/ros/noetic/lib/python3/dist-packages/rospy/topics.py", line 1066, in publish
serialize_message(b, self.seq, message)
File "/opt/ros/noetic/lib/python3/dist-packages/rospy/msg.py", line 152, in serialize_message
msg.serialize(b)
File "/home/user/catkin_ws/devel/lib/python3/dist-packages/turtlebot3_move/msg/_OdomRecordActionResult.py", line 163, in serialize
buff.write(_get_struct_3d().pack(_x.x, _x.y, _x.z))
AttributeError: 'function' object has no attribute 'x'
[ERROR] [1633178800.248160, 1743.189000]: To transition to an aborted state, the goal must be in a preempting or active state, it is currently in state: 3
