Hello Community,
I am working on the rosject of the course ROS2 Basics in 5 Days(Python).
For part 3 of the rosject, I need to build a custom action interface that looks like below:
Point[] list_of_odoms
float32 current_total
I noticed that the interface depends on the Point interface, so I guess I have modified the CMakeLists.txt and package.xml.
I have made following changes:
- Added
find_package(geometry_msgs REQUIRED)in the CMakeLists.txt - Added
<depend>geometry_msgs</depend>in the package.xml
However, when I called colcon build to build the custom interface, it shows the following error:
fatal error: custom_interfaces/msg/detail/point__struct.h: No such file or directory
41 | #include "custom_interfaces/msg/detail/point__struct.h"
Not sure what I have missed. Are there any additional steps I need to do?
Below is the content of those two files after I edited them.
CMakeLists.txt
cmake_minimum_required(VERSION 3.5)
project(custom_interfaces)
# Default to C99
if(NOT CMAKE_C_STANDARD)
set(CMAKE_C_STANDARD 99)
endif()
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
set(CMAKE_CXX_STANDARD 14)
endif()
endif()
# find dependencies
find_package(rclcpp REQUIRED)
find_package(std_msgs REQUIRED)
#Added for Point dependency
find_package(rosidl_default_generators REQUIRED)
rosidl_generate_interfaces(${PROJECT_NAME}
"srv/Wall.srv"
"action/OdomRecord.action"
if(BUILD_TESTING)
# uncomment the line when a copyright and license is not present in all source files
#set(ament_cmake_copyright_FOUND TRUE)
# uncomment the line when this package is not in a git repo
#set(ament_cmake_cpplint_FOUND TRUE)
endif()
ament_package()
<?xml version="1.0"?>
<package format="3">
<name>custom_interfaces</name>
<version>0.0.0</version>
<buildtool_depend>ament_cmake</buildtool_depend>
<depend>rclcpp</depend>
<depend>action_msgs</depend>
<depend>rosidl_default_generators</depend>
<exec_depend>rosidl_default_runtime</exec_depend>
<member_of_group>rosidl_interface_packages</member_of_group>
<test_depend>ament_lint_auto</test_depend>
<test_depend>ament_lint_common</test_depend>
<export>
<build_type>ament_cmake</build_type>
</export>
</package>
This works.
