Hi, I am trying to use rosjet and import my project there. however in order to install the one of the prerequisite libaries i have to use “sudo” command where i will need to know the password used for user account. May i know what is the password please ?
Hi @louis,
Just use sudo whenever you need to, it won’t ask for a password.
Thank you for your reply, however it does request for password. I have attached a screenshot of the message for your perusal.
Hi @louis,
I don’t know why it’s asking for a password in this case. It shouldn’t. Can you tell us what other commands you have run before this? Can you copy/paste the commands run, from the beginning up to the point where it asked for a password?
Hi @bayodesegun
I just clone a repo ran “make” command in the directory and after that ran “sudo make install”. if you wanna try it yourself you can make a new peoject and run the following commands:
wget https://github.com/joan2937/pigpio/archive/master.zip
unzip master.zip
cd pigpio-master
make
sudo make install
Hi @louis,
I just did that. See excerpts:
user:~$ cd pigpio-master
user:~/pigpio-master$ make
gcc -O3 -Wall -pthread -fpic -c -o pigpio.o pigpio.c
gcc -O3 -Wall -pthread -fpic -c -o command.o command.c
gcc -shared -pthread -Wl,-soname,libpigpio.so.1 -o libpigpio.so.1 pigpio.o command.o
strip pigs
user:~/pigpio-master$ sudo make install
install -m 0755 -d /opt/pigpio/cgi
install -m 0755 -d /usr/local/include
Hi @bayodesegun
Thank you for your response. I can use the sudo command in the shell now. I guess the problem was because I was using the terminal from the IDE.
