Roslaunch error at 'ROS Deep Learning with TensorFlow 101, Unit 1-Step 4'
Hi there
In the course ’ ROS Deep Learning with TensorFlow 101, Unit 1-Step 4: You are ready to run’
I have tried to run the roslaunch file, error has occurred as follows.
any suggestion is welcome
user:~/catkin_ws/src/tf_unit1_pkg$ roslaunch tf_unit1_pkg start_image_recognition.launch
… logging to /home/user/.ros/log/9da434da-253e-11ea-9b1b-069fc351ab34/roslaunch-rosdscomputer-24437.log
Press Ctrl-C to interrupt
started roslaunch server http://rosdscomputer:41123/
SUMMARY
PARAMETERS
  • /rosdistro: kinetic
  • /rosversion: 1.12.14
NODES
rostensorflow_image_recognition_node (tf_unit1_pkg/image_recognition.py)
ROS_MASTER_URI=http://master:11311
ERROR: cannot launch node of type [tf_unit1_pkg/image_recognition.py]: can’t locate node [image_recognition.py] in package [tf_unit1_pkg]
No processes to monitor
Hi there
This ticket was solved already by duckfrost in post #4.
Thanks
