Rosrun move_bb8_pkg move_bb8_square.py takes too long?
Hello guys,
I’m taking Linux for robotics course right now and I’m on exercise 3.1.
My question is why rosrun move_bb8_pkg move_bb8_square.py execution takes forever to run. Eventually when I use ctrl + c to close the execution. I get this error!
^Cfrom: can’t read /var/mail/geometry_msgs.msg
^C^C/home/user/catkin_ws/src/linux_course_files/move_bb8_pkg/my_scripts/move_bb8_square.py: line 6: syntax error near unexpected token (' /home/user/catkin_ws/src/linux_course_files/move_bb8_pkg/my_scripts/move_bb8_square.py: line 6: class MoveBB8():’
I don’t know what to do?
Hi @leonar29 ,
this happens because your python script is being interpreted as a bash script.
To solve the problem you just have to add the following code to the first line of your script:
This way, when the script is executed, python will be used to run your script instead of bash.
Cheers.
Thank you so much! it worked!
Hello all, I am totally new to Linux and ROS. I am practicing on these tutorials. I got similar error but not exactly same. Actually, it gives this when I try to implement the “rosrun” command >>
user:~/catkin_ws/src/linux_course_files/move_bb8_pkg/my_scripts
$ rosrun move_bb8_pkg move_bb8_square.py
import: unable to grab mouse ': Resource temporarily unavailable @ error/xwindow.c/XSelectWindow/9204. from: can't read /var/mail/geometry_msgs.msg import: unable to grab mouse ‘: Resource temporarily unavailable @ error/xwindow.c/XSelectWindow/9204.
import: unable to grab mouse ': Resource temporarily unavailable @ error/xwindow.c/XSelectWindow/9204. /home/user/catkin_ws/src/linux_course_files/move_bb8_pkg/my_scripts/move_bb8_square.py: line 8: syntax error near unexpected token (’
/home/user/catkin_ws/src/linux_course_files/move_bb8_pkg/my_scripts/move_bb8_square.py: line 8: `class MoveBB8():’
What should I do to rectify it?
Hi @arjun2312,
if your script does not have that line:
then you have to add it to the first line of your script.
All python scripts executed with rosrun needs that code in the first tline.
