I got the above result with no simulation result. Could anyone enlighten me as to why i see no rosrun error and no simulation result?
Hi @tesfayewakessa,
I’m been trying to reproduce the error, but I couldn’t. In my case, it is working as expected.
If the problem persists, could you copy the content from the notebook and paste it in the move_bb8_square.py again?
The content is the following:
#!/usr/bin/env python
import time
import math
class MoveBB8():
self.bb8_vel_publisher = rospy.Publisher('/cmd_vel', Twist, queue_size=1)
self.cmd = Twist()
self.ctrl_c = False
self.rate = rospy.Rate(10)
def publish_once_in_cmd_vel(self):
This is because publishing in topics sometimes fails the first time you publish.
In continuous publishing systems, this is no big deal, but in systems that publish only
once, it IS very important.
while not self.ctrl_c:
connections = self.bb8_vel_publisher.get_num_connections()
if connections > 0:
self.bb8_vel_publisher.publish(self.cmd)
rospy.loginfo("Cmd Published")
break
else:
self.rate.sleep()
def shutdownhook(self):
# works better than the rospy.is_shut_down()
self.stop_bb8()
self.ctrl_c = True
def stop_bb8(self):
rospy.loginfo("shutdown time! Stop the robot")
self.cmd.linear.x = 0.0
self.cmd.angular.z = 0.0
self.publish_once_in_cmd_vel()
def move_x_time(self, moving_time, linear_speed=0.2, angular_speed=0.2):
self.cmd.linear.x = linear_speed
self.cmd.angular.z = angular_speed
time.sleep(moving_time)
def move_square(self):
i = 0
while not self.ctrl_c and i < 4:
# Move Forward
self.move_x_time(moving_time=4.0, linear_speed=0.2, angular_speed=0.0)
# Turn, the turning is not affected by the length of the side we want
self.move_x_time(moving_time=4.0, linear_speed=0.0, angular_speed=0.2)
i += 1
self.stop_bb8()
rospy.loginfo("######## Finished Moving in a Square")
if __name__ == '__main__':
rospy.init_node('move_bb8_test', anonymous=True)
movebb8_object = MoveBB8()
try:
movebb8_object.move_square()
pass
Please let me know in case the problem persists.
Cheers,
Hello The construct,
First of all, thank you for this excellent content. I am facing trouble that the simulation is not running when I execute rosrun move_bb8_pkg move_bb8_square.py.Instead, I got the following error msg. I will appreciate if anyone can help me regarding this
Hello @Aminul,
It seems to be a syntax error in your code.
It says “line 9”
Do you mind to share it with us? So we can check it together
Regards
Thank you, arruda.
I was able to figure out the mistake I did, now it is working.
Thanks again for the great content.
Hey @tesfayewakessa
Could you pls share what you did to fix this problem. I’m having exactly the same issue.
Thanks
Hi @Cobra711 ,
it seems the problem is that you have to add the following content, known as shebang, as the first line of your script:
