Hi everyone
I’m starting the ROS2 Navigation Advanced course. The Rviz config files that are supported in the repo don’t load the map…I don’t know what rviz file should I use.
Thanks in advance
Hello @lfernandez ,
Could you please provide some more details on this? What unit are you working on? What exercise/section? Are you getting any kind of error?
Thanks in advance,
Hello @albertoezquerro
I’m working on the frist unit. I don’t know where is the rviz config file I should use.
I’ve tried with the ones included in ~/ros2_ws/src/nav2_pkgs/path_planner_server/rviz_config
Thanks again
Hello @lfernandez ,
The Rviz config file is loaded automatically. The steps to follow are:
- Download the repo:
cd ~/ros2_ws/src
git clone https://bitbucket.org/theconstructcore/nav2_pkgs.git
- Compile your workspace:
cd ~/ros2_ws/
colcon build
source install/setup.bash
- Launch Nav2:
ros2 launch path_planner_server navigation.launch.py
RViz2 will be loaded automatically and you should get something like this:
Thanks @albertoezquerro!!
