I think there is something wrong in the platform. I have been having problem loading rviz in any of the courses. The problem is quite odd. when i load rviz from terminal, I think the GUI loads but its too small about the size of 10mm x 10mm.
Please could someone suggest whats the problem.
when the new window appears and a small cube is at the bottom which i believe is the rviz GUI.
I believe this problem is caused due to one of the browser extensions interfering with the user interface of The Construct webpage.
Switch over to a chromium based browser, like Google Chrome, chromium, Opera or other browsers like Firefox or Vivaldi.
If you don’t want to switch to new browser, the other option for you is to try disabling each browser extension you have installed and find out which extension is causing this issue with RViz screen on The Construct portal.
I hope this helps.
Let us know which browser extension you disabled to get it working. That way we can know what is interfering with the platform and find suitable solution to bypass this issue!
