the map doesn’t showed up in rviz although the tf and laser scan are working
Hi @yairnakai, welcome to the community!
Are you trying to perform mapping or use an existing map in the map_server
? You need to check that either of these two nodes are doing their jobs. Check the terminal where you launched them
