Segmentation fault (core dumped) - C++ for Robotics
Have reported this through the workspace, but was asked to post it here.
In “C++ for Robotics - section 4: Arrays” a Segmentation fault was occurring. No other error messages given. It was found that rosbot.move() had to be called before rosbot.get_laser(int idx) and therefore has to be a bug in the underlying source code somewhere i.e. something wasn’t initialized.
Possible solution:
Under the script rosbot_class.cpp in each of the move commands the publishing rate has been set, whereas within the get_laser method it is not set.
Found that calling ros::spinOnce() solved the segmentation fault, needs to be added to get_laser()
Move:
void RosbotClass::move() {
  // Rate of publishing
  ros::Rate rate(10);
  ros::Time start_time = ros::Time::now();
  ros::Duration timeout(2.0); // Timeout of 2 seconds
  while (ros::Time::now() - start_time < timeout) {
    ros::spinOnce();
    vel_msg.linear.x = +0.5;
    vel_msg.angular.z = 0.0;
    vel_pub.publish(vel_msg);
    rate.sleep();
  vel_msg.linear.x = 0.0;
Laser:
float RosbotClass::get_laser(int index) { return laser_range[index]; }
float *RosbotClass::get_laser_full() {
  float *laser_range_pointer = laser_range.data();
  return laser_range_pointer;
This error happened again in the next section: Classes.
Even though I was calling move() beforehand I was still getting this error at the end of my program, whereas it previously it just wouldn’t run at all.
Here is my solution that created the fault:
Edit: below had a circular call for the move() method.
#include "rosbot_control/rosbot_class.h"
#include <ros/ros.h>
#include <string>
using namespace std;
class RosBotWithNav : private RosbotClass {
public:
  void turn_left_90_deg() { this->turn("counterclockwise", 3); }
  void turn_right_90_deg() { this->turn("clockwise", 3); }
  void move_up_to_next() {
    this->move_forward(1);
    while (this->get_laser(0) > 2) {
  void move_along_obstacle() {
    while (this->get_laser(180) < 5) {
  void move() { this->move(); } // <-- circular error
  ros::init(argc, argv, "Rosbot_move_node");
  RosBotWithNav rosbot;
  rosbot.move_up_to_next();
  rosbot.turn_left_90_deg();
  rosbot.move_along_obstacle();
  rosbot.turn_right_90_deg();
  rosbot.move();
Hello @josiahbrough ,
Many thanks for the feedback. I’ve been doing some tests to confirm this behavior. I’ve created an issue and we will fix it as soon as possible.
This issue has been solved.
