I do not why I get a error message that says file is not executable. All files show as “green” in the IDE.
Hi @ROxX ,
You get the “No executable found” error because the names of the executable that you have defined in the setup.py file are client and server.
So naturally, if you try to start an executable whose name does not match the specified name, you will get an error.
The command that you should use is:
ros2 run services_quiz client
and not
ros2 run services_quiz quiz_client
I hope this clarified your issue!
Regards.
