Services Quiz. Gradebot Fails to compile the package. How fix it?
Gradebot says:
Feedback from the last successful autocorrection:
:check_mark: [info] Setting up ROS2 environment (mark: 0)
:check_mark: [info] ROS2 environment setup is okay (mark: 0)
:check_mark: [assess] services_quiz package found (mark: .5)
:check_mark: [assess] services_quiz_srv package found (mark: 1.0)
:check_mark: [info] compiling packages services_quiz and services_quiz_srv… (mark: 1.0)
:multiply: [assess] The services_quiz and services_quiz_srv packages did not compile successfully. Let’s fix this before we continue.
Things you can check before retrying:
  • Run colcon build --packages-select services_quiz services_quiz_srv and ensure it compiles without an error. (mark: 1.0)
user:~/ros2_ws$ colcon build --packages-select services_quiz
Starting >>> services_quiz
— stderr: services_quiz
/usr/lib/python3/dist-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
Finished <<< services_quiz [2.42s]
Summary: 1 package finished [3.27s]
1 package had stderr output: services_quiz
user:~/ros2_ws$
How fix it?
Although the packages were compiled before being submitted to GradeBot (services_quiz_srv no errors, services_quiz with a warning message but no errors).
Hello @oleg.a.kuvaev ,
As indicated in the other post, I solve this by removing the current compilation files and rebuilding the workspace:
cd ~/ros2_ws
rm -rf build install log
colcon build
Also, I saw that you had some compilation files inside ~/ros2_ws/src :
You MUST only compile in the root of the workspace /home/user/ros2_ws and nowhere else. So all the compilation folders/files that are outside the root of the workspace must be removed.
This did not solve the problem.
Packages are compiled before being sent to GradeBot. Executed by a robot.
GradeBot gives a compilation error (there are 2 attempts left, this is already bothering me a little).
What’s wrong?
Hi @oleg.a.kuvaev ,
setuptools installed in your environment is probably a wrong version.
Try the following command on your terminal:
pip install setuptools==58.2.0
Source: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools. - ROS Answers: Open Source Q&A Forum
Please let us know if the problem gets fixed!
setuptools warning solved. Thank you.
Hi @oleg.a.kuvaev ,
Amazing!!! Glad that it worked for you!
I hope now you can submit your work to gradebot. Hopefully this time you won’t face any issues!
But this did not solve the global problem. GradeBot still throws a compilation error.
What’s wrong? I don’t understand :frowning:
Hi @oleg.a.kuvaev ,
Don’t panic!!! If you use up all your attempts, it can be reset by TheConstruct team.
Currently, there seems to be a problem with gradebot for this specific exercise:
Refer: ROS2 Basics in 5 Days Humble (C++) - 4.7 Services Quiz - #5 by albertoezquerro
Keep following that post to stay informed when the problem gets fixed.
Greate :smiley:
My solution for this mistake:
  1. cd ~/ros2_ws and rm -rf build install log
  2. colcon build
  3. Verify in simulations
  4. Again cd ~/ros2_ws and rm -rf build install log
  5. Sent to GradeBot WITHOUT colcon build
Profit :slight_smile:
Hi @oleg.a.kuvaev ,
Awesome! You have found the solution yourself!
Also, thanks for sharing it!
I was about to suggest you this step. But I was slightly unsure if that would work.
Anyways glad you solved it!
