I stuck with the services quiz.
The robot is rotating correctly, but I assume that the problem is that the service is returning True before the actual turn.
I tried to wait for the end of rotation by using the while loop, but it blocks the whole program.
How to modify the code to return the execution status after rotation, not when starting it?
This is my code:
from services_quiz_srv.srv import Turn
import rclpy
from rclpy.node import Node
class Services_quiz_server_node(Node):
super().__init__('services_quiz_server_node')
self.srv = self.create_service(Turn, 'turn', self.custom_service_callback)
self.waitDone = False
self.angular_velocity = 0.0
self.time_since_timer_start = 0.0
self.time_interval = 0.01
self.motion_timer = self.create_timer(self.time_interval, self.motion)
def custom_service_callback(self, request, response):
direction = request.direction
coeff = 0
if direction == "left":
coeff = 1
self.get_logger().info('Turning left!!')
elif direction == "right":
coeff = -1
self.get_logger().info('Turning right!!')
else:
coeff = 0
self.get_logger().info('Incorrect value')
self.angular_velocity = request.angular_velocity * coeff
self.time = request.time
self.timer = self.create_timer(self.time_interval, self.timer_callback)
response.success = True
return response
def timer_callback(self):
self.get_logger().info('timer_callback')
self.time_since_timer_start += self.time_interval
if self.time_since_timer_start >= self.time:
self.waitDone = True
self.timer.cancel()
self.get_logger().info('Time to stop')
self.timer.cancel()
else:
self.get_logger().info('Still waiting')
def motion(self):
msg = Twist()
msg.linear.x = 0.0
if not self.waitDone:
msg.angular.z = self.angular_velocity
# self.get_logger().info('Rotation in progress')
else:
msg.angular.z = 0.0
self.publisher_.publish(msg)
def main(args=None):
rclpy.init(args=args)
services_quiz_server_node = Services_quiz_server_node()
rclpy.spin(services_quiz_server_node)
rclpy.shutdown()
if __name__ == '__main__':
main()
I think the problem is here:
return response
How do I finish the execution of custom_service_callback function without sending True?
Can I return the value later from another function?
I actually need to return True from this part of code:
self.timer.cancel()
self.timer.cancel()
#Return status here
