Hello. @girishkumar.kannan , @bayodesegun
I could use a quick check on the video below. ( low res - due to size upload limit )
The bot seems to be using a step, i miss at the env setup.
After i execute the grader bot, the pkg is not found again.
Thanks for your time in advance.
Your packages failed to compile because you did not set up the dependencies correctly.
services_quiz must only depend on services_quiz_srv. That dependency must be correctly set up, as described in the notes.
services_quiz_srv must not depend on any other package in your workspace. Otherwise, gradebot will not be able to compile it.
You can check that with:
cd ~/ros2_ws
rm -rf build/ install/ log/
colcon build --packages-select services_quiz services_quiz_srv
This was the point of failure.
When correctly set up, services_quiz_srv would be compiled first, then services_quiz would be compiled.
Thanks for the tip. It was missing the dependency in package.xml.
<depend>services_quiz_srv</depend>
I crossed that after.
system
Closed
January 18, 2025, 11:40am
4
