"setup.py install is deprecated" when building specific package
user:~/ros2_ws$ colcon build --packages-select my_package
Starting >>> my_package
— stderr: my_package
/usr/lib/python3/dist-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
Hi @JamesNewton ,
Welcome to this Community!
The most common solution would be to downgrade the version of setuptools that is currently installed on the virtual machine.
Run the below command on a terminal in your environment.
pip install setuptools==58.2.0
This should fix your problem. Let me know if the problem still persists.
