t>There is a deprecation warning in Python version of ROS2 Basics in 5 days (Humble) related to [this issue](https://ros2 service call /moving std_srvs/srv/Empty) the fix is simply to run
pip install setuptools==58.2
Thank you for pointing it out. We’ll look into making the fix permanent for the course.
Is this happening in the course or the rosject? If course, could you please mention the specific unit?
