./simple_patrol_sim.bash don't run or rather doesn't output anything
At the end of Linux for Robotics course, just before moving to the real robot ./simple_patrol_sim.bash don’t run or rather doesn’t output anything
I am running simulation in one terminal, teleop in second terminal, 3rd terminal is interface.py and the 4th terminal where I should run ./simple_patrol_sim.bash, nothing happens.
Simulation:
  1. In a new Terminal window, launch the Gazebo simulation using the commands specified in the Launching the Simulation section above.
  2. In a second new Terminal window, launch the Robot Interface program.
  • After starting the program, wait for 5 seconds for the program to initialize and print READY !!!.
Execute in Terminal
cd ~/ros2_ws/src/linux_basics_project/linux_basics_project/
./robot_interface.py
  1. In a third new Terminal window, launch the Simple Patrol (Sim) program. This program will make the robot start moving around the arena.
  • Note: Make sure that the Robot Interface program is ready, otherwise the robot will not start moving!
Execute in Terminal
Here is a sample output animation of the Simple Patrol program in the Simulation environment. Note that the algorithm works with a lot of uncertainty (randomness). So the your output can be different from what is shown in the below animation. You will not get the exact same results.
Hi @Abe_123, welcome to the community!
I just tested the exercise in the rosject and it works as intended.
Please go through the instructions carefully, the most likely scenario is that you have missed a step. For example:
  • Have you moved robot_interface.py and simple_patrol_sim.bash to the correct location?
  • Have you made the scripts executable?
  • Are you in the correct location before running the scripts?
  • Can you see the simulation and RViZ?
Please share the outputs of your terminals so I can help you find the issue.
Thank you
