When I try to login with my google account, it does not proceeds. It continuously comes back to the login page
I apologize for this. We are currently having problems with out Facebook and Google login.
Please use the “Forgot password” link to set a password for your account, and then log in with username and password.
@lamfeto12
Here is the full procedure for setting a password for your account:
A. Case 1: if you are trying to create an account (new user), please use the “Sign Up” button. You do not need to follow the steps below.
B. Case 2: if you are trying to log in (returning user), please follow the steps below.
- Go to the app.theconstruct.ai page.
- Click on the “Forgot Password?” option.
- Type your Google or Facebook email (depending on which social login you registered for) and press “Send email”.
- Check your email for an email from us with the subject
The Construct password rest. On that email you will see a line that says something like:
To complete the password reset process for your username account on The Construct, click the link below:
https://app.theconstruct.ai/users/password_reset/?token=xxx
- Click on the link. It should take you to a page where you will set a new password.
- Type a new password in the space provided and click “Set new password”. Your new password is set, and you are redirected to the login page.
- Log in with your email and password.
This problem is now fixed. Should you run into this again, please try the following, in order, trying again after each step:
- Refresh the page to get the latest update.
- Ensure a pop-up blocker is not blocking the window.
- Contact us if the problem persists.
Thank you all for your patience.
