As the solutions are not available on the topic, i wanted to share mine for other students.
Feel free to comment or correct
- Create a test suite for all my ROS service tests
- Add test cases like:
* Testing ifstop_robot()actually stops the robot
* What happens when invalid input is passed to the/rotate_robotservice - Modify the core service code so all tests pass
Files Included
rotate_robot_complete.py– the full service + classrotate_robot_test_final.py– the test suiterotate_robot_test.launch– test runner forrostest
What’s Tested
Service: /rotate_robot
- Inputs: angular speed (°/s), angle (°), and clockwise (
y/n) - Invalid direction input like
'f'or'x'returnsrotation_successfull = False
stop_robot()
- Unit test ensures calling
stop_robot()results inlinear.x = 0.0andangular.z = 0.0
Publish check
- Confirms velocity commands are published successfully to
/cmd_vel
<launch>
<node pkg="robot_control" type="rotate_robot_complete.py" name='rotate_robot_srv_node'/>
<test test-name="rotate_robot_test_ros_srv" pkg="robot_control" type="rotate_robot_test_final.py"/>
</launch>
from robot_control.rotate_robot_complete import RobotControl
from robot_control.srv import RotateRobot, RotateRobotRequest
import rosunit
import unittest
import rostest
import time
PKG = 'robot_control'
NAME = 'rotate_robot_test_ros_srv'
class TestRobotControl(unittest.TestCase):
# In Python's unittest, the setUp() method is run once per test method.
# Use @classmethod with setUpClass() if you want to only instantiate RobotControl() once for the entire test class
@classmethod
def setUpClass(cls):
cls.rc = RobotControl()
cls.success = False
rospy.loginfo("SetUpClass Done")
# def setUp(self):
# self.rc = RobotControl(start_service = False)
# rospy.loginfo("SetUp Done")
# self.success = False
def callback(self, msg):
print(rospy.get_caller_id(), "Angular Speed: %s" % msg.angular.z)
self.success = msg.angular.z and msg.angular.z == 1
def test_publish_cmd_vel(self):
rospy.loginfo("\nRunning Test Publish cmd ")
test_sub = rospy.Subscriber("/cmd_vel", Twist, self.callback)
self.rc.cmd.angular.z = 1
self.rc.publish_once_in_cmd_vel()
timeout_t = time.time() + 10.0 # 10 seconds
while not rospy.is_shutdown() and not self.success and time.time() < timeout_t:
time.sleep(0.1)
self.assert_(self.success)
def test_rotate_robot_service(self):
rospy.loginfo("\nRunning Test Rotate Service ")
rospy.wait_for_service('rotate_robot')
s = rospy.ServiceProxy('rotate_robot', RotateRobot)
# test = [(60,90,'y'), (43,'d','y')]
test = [
(60, 90, 'y', True), # valid
(43, 43, 'f', False), # invalid
(30, 30, 'n', True), # valid
(10, 10, 'x', False), # invalid
for x,y,z,expected_success in test:
print("Requesting %s + %s + %s" % (x,y,z))
#test both simple and formal call syntax
resp = s(x,y,z)
resp2 = s.call(RotateRobotRequest(x,y,z))
# self.assertEquals(resp.rotation_successfull, resp2.rotation_successfull)
# self.assertTrue(resp.rotation_successfull, "integration failure, service responce was not True")
self.assertEqual(resp.rotation_successfull, expected_success, "Failed for input {}".format(z))
def test_stop_robot(self):
# Set some dummy motion values before calling stop
rospy.loginfo("\nRunning Test STOP")
self.rc.cmd.linear.x = 1.5
self.rc.cmd.angular.z = 2.5
self.rc.stop_robot()
rospy.loginfo("Robot Stopped, Vel angular.z = %f", self.rc.cmd.angular.z)
self.assertEqual(self.rc.cmd.linear.x, 0.0, "Expected linear.x to be 0.0 after stop_robot")
self.assertEqual(self.rc.cmd.angular.z, 0.0, "Expected angular.z to be 0.0 after stop_robot")
if __name__ == '__main__':
rostest.rosrun(PKG,NAME,TestRobotControl)
Description
This Python script contains unit and integration tests for the RobotControl class using unittest and rostest.
It verifies that the robot correctly publishes to /cmd_vel and that the /rotate_robot service works as expected.
## Test Cases
1. **test_publish_cmd_vel**
Publishes an angular velocity (angular.z = 1) to /cmd_vel.
Checks if the message is received successfully.
2. **test_rotate_robot_service**
Calls the /rotate_robot service with test values (speed, angle, direction).
Verifies that the service responds with rotation_successfull == True.
Compares both simple and formal service call formats.
## Usage
**Step 1:** Run the service node in a separate terminal:
bash
rosrun robot_control rotate_robot_complete.py
#!/usr/bin/env python
from robot_control.srv import RotateRobot, RotateRobotResponse
import time
import math
class RobotControl():
def __init__(self, start_service=True):
rospy.init_node('robot_control_node', anonymous=True)
self.vel_publisher = rospy.Publisher('/cmd_vel', Twist, queue_size=1)
if start_service:
self.service_server = rospy.Service('rotate_robot', RotateRobot, self.srv_callback)
rospy.loginfo("Class instanciate")
self.cmd = Twist()
self.ctrl_c = False
self.rate = rospy.Rate(10)
def srv_callback(self, request):
# Initilize velocities
self.cmd.linear.x = 0
self.cmd.linear.y = 0
self.cmd.linear.z = 0
self.cmd.angular.x = 0
self.cmd.angular.y = 0
response = RotateRobotResponse()
self.convert_degree_to_rad(request.speed_d, request.angle_d)
if request.clockwise_yn == "y":
self.clockwise = True
elif request.clockwise_yn == "n":
self.clockwise = False
else:
response.rotation_successfull = False
return response
if self.clockwise:
print ("Clockwise")
self.cmd.angular.z = -abs(self.angular_speed_r)
else:
print ("Not clockwise")
self.cmd.angular.z = abs(self.angular_speed_r)
# t0 is the current time
t0 = rospy.Time.now().secs
current_angle = 0
# loop to publish the velocity estimate, current_distance = velocity * (t1 - t0)
while (current_angle < self.angle_r):
# Publish the velocity
self.vel_publisher.publish(self.cmd)
# t1 is the current time
t1 = rospy.Time.now().secs
# Calculate current_distance
current_angle = self.angular_speed_r * (t1 - t0)
# ros::spinOnce();
self.rate.sleep()
# set velocity to zero to stop the robot
self.stop_robot()
response.rotation_successfull = True
return response
def publish_once_in_cmd_vel(self):
This is because publishing in topics sometimes fails the first time you publish.
In continuos publishing systems there is no big deal but in systems that publish only
once it IS very important.
while not self.ctrl_c:
connections = self.vel_publisher.get_num_connections()
if connections > 0:
#rospy.loginfo("Cmd Published")
break
else:
self.rate.sleep()
def shutdownhook(self):
# works better than the rospy.is_shutdown()
self.stop_robot()
self.ctrl_c = True
def stop_robot(self):
#rospy.loginfo("shutdown time! Stop the robot")
self.cmd.linear.x = 0.0
self.cmd.angular.z = 0.0
self.publish_once_in_cmd_vel()
def convert_degree_to_rad(self, speed_deg, angle_deg):
self.angular_speed_r = speed_deg * 3.14 / 180
self.angle_r = angle_deg * 3.14 / 180
return [self.angular_speed_r, self.angle_r]
def rotate(self):
speed_d, angle_d = self.get_inputs_rotate()
self.convert_degree_to_rad(speed_d, angle_d)
print (self.clockwise)
if self.clockwise:
else:
current_angle = 0
# ros::spinOnce();
self.rate.sleep()
self.stop_robot()
def get_inputs_rotate(self):
self.angular_speed_d = int( raw_input('Enter desired angular speed (degrees): '))
self.angle_d = int(raw_input('Enter desired angle (degrees): '))
clockwise_yn = raw_input('Do you want to rotate clockwise? (y/n): ')
if clockwise_yn == "y":
if clockwise_yn == "n":
return [self.angular_speed_d, self.angle_d]
#rospy.init_node('robot_control_node', anonymous=True)
robotcontrol_object = RobotControl()
rospy.spin()
## Description
This ROS node implements the RobotControl class, which allows a mobile robot to rotate by publishing angular velocity commands.
It also provides a service called /rotate_robot that enables the robot to rotate by a specified angle, speed, and direction (clockwise or counterclockwise).
## Features
- Publishes velocity commands to the /cmd_vel topic using Twist messages.
- Provides a service /rotate_robot (type RotateRobot.srv) that:
- Takes input parameters: angular speed (degrees/sec), angle (degrees), and direction (y or n for clockwise).
- Converts degrees to radians and sends angular commands until the target rotation is reached.
- Includes helper methods for:
- Publishing once to /cmd_vel safely.
- Stopping the robot on shutdown.
- Manual command-line rotation input.
## Usage
Run the node with:
bash
