Solution to the Actions Quiz
I have submitted and passed the Actions Quiz (7.9). Usually, at this point, we are able to see the solutions for the quiz (which sort of helps me understand the approach better).
But for 7.9, I was not able to view The Construct’s solution.
Has anyone faced a similar issue?
Ninad Mehta
Could you please clarify what this means? Did you click on the Check solution button and nothing happened? Or what?
I didn’t get the ‘Check Solution’ button. I submitted thrice at different timings to avoid any errors on my end. Every time I submitted, I only got my marks but no ‘Check Solution’ once the checking was done.
Hope that clarifies the issue.
Thanks for clarifying. I apologize for the glitch.
Please click the Submit button, and you should now see the Check Solution button.
We only show the Check Solution button if the user achieved a perfect grade at any attempt (your case), or at the very last attempt. The former part of this condition didn’t work as expected (looking into it).
I did a “hack” for you to see this button - I increased your attempts to 5. I sure hope you don’t need your remaining 2 attempts anymore :cold_sweat:
PS: any unused attempts cannot be exchanged for money anyway:wink: :grin: and would no longer be relevant once you check the solution
Haha. I just re-submitted it and was able to see the solution.
Thank you!
