Thank You for the help I appreciate it. How can I upload the files it says that the allowed formats are only pictures.
Hi @IdrisOm ,
Thanks for sharing the files.
For now I have fixed the my_custom_srv_msg_pkg package. Your custom message format is correct, I am assuming you copy-pasted from tutorial.
Your CMakeLists.txt had two problems: I have fixed it!
- You forgot to include
rospyunderfind_package - You should include
std_msgsundercatkin_packageand removemy_custom_srv_msg_pkg
Your package.xml had the dependencies in wrong order: I have fixed this also!
Here are your modified (fixed) files for my_custom_srv_msg_pkg package: copy-paste into your files.
CMakeLists.txt
project(my_custom_srv_msg_pkg)
## Here is where all the packages needed to COMPILE the messages of topics, services and actions go.
## It's only getting its paths, and not really importing them to be used in the compilation.
## It's only for further functions in CMakeLists.txt to be able to find those packages.
## In package.xml you have to state them as build
rospy
std_msgs
message_generation
## In this function will be all the action messages of this package ( in the action folder ) to be compiled.
## You can state that it gets all the actions inside the action directory: DIRECTORY action
## Or just the action messages stated explicitly: FILES my_custom_action.action
## In your case you only need to do one of two things, as you wish.
add_service_files(
FILES
MyCustomServiceMessage.srv
## Here is where the packages needed for the action messages compilation are imported.
generate_messages(
DEPENDENCIES
std_msgs
## State here all the packages that will be needed by someone that executes something from your package.
## All the packages stated here must be in the package.xml as exec_depend
catkin_package(
CATKIN_DEPENDS rospy std_msgs
include_directories(
${catkin_INCLUDE_DIRS}
package.xml
<?xml version="1.0"?>
<package format="2">
<name>my_custom_srv_msg_pkg</name>
<version>0.0.0</version>
<description>The my_custom_srv_msg_pkg package</description>
<license>TODO</license>
<export>
</export>
</package>
Hi @IdrisOm ,
Fixed your my_examples_pkg package.
Here are the problems you had:
- You imported
my_custom_service_pkg.srvinstead ofmy_custom_srv_msg_pkg.srv- so there was wrong package name - which is why you got module not found error - becausemy_custom_service_pkgnever existed. - In your CMakeLists.txt file:
a. You do not requiremessage_generationunderfind_package- I removed that line.
b. You do not requireMyCustomServiceMessage.srvunderadd_service_files- I removed that line.
c. You do not requireadd_dependencies(my_custom_srv_msg_pkg ${catkin_EXPORTED_TARGETS})
d. You do not requiremy_custom_srv_msg_pkgundercatkin_package - Your package.xml file was not in proper order.
Now everything is fixed and tested.
Here are your modified files:
custom_service_server.py:
from my_custom_srv_msg_pkg.srv import MyCustomServiceMessage, MyCustomServiceMessageResponse
def my_callback(request):
print("Request Data==> duration="+str(request.duration))
my_response = MyCustomServiceMessageResponse()
if request.duration > 5.0:
my_response.success = True
else:
my_response.success = False
# the service Response class, in this case MyCustomServiceMessageResponse
return my_response
rospy.init_node('service_client')
# create the Service called my_service with the defined callback
my_service = rospy.Service('/my_service', MyCustomServiceMessage, my_callback)
rospy.spin() # maintain the service open.
CMakeLists.txt:
project(my_examples_pkg)
rospy
std_msgs
# catkin_python_setup()
## * In the file package.xml:
add_message_files(
FILES
Age.msg
# Message1.msg
# Message2.msg
#add_service_files(
# FILES
# Service1.srv
# Service2.srv
#add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES my_examples_pkg
# DEPENDS system_lib
## Build ##
# include
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/my_examples_pkg.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/my_examples_pkg_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_my_examples_pkg.cpp)
# endif()
# catkin_add_nosetests(test)
package.xml:
<name>my_examples_pkg</name>
<description>The my_examples_pkg package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/my_examples_pkg</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<build_depend>my_custom_srv_msg_pkg</build_depend>
<build_export_depend>my_custom_srv_msg_pkg</build_export_depend>
<exec_depend>my_custom_srv_msg_pkg</exec_depend>
<export>
</export>
</package>
Everything should now work fine.
@IdrisOm ,
Final words, you must pay attention to what you are doing throughout the tutorial.
You said you created my_custom_srv_msg_pkg from scratch for more than 3 times, but all of them were created wrong.
Also follow the tutorial properly. You tried to include all scripts in one single package instead of dedicated individual packages for each exercise.
You are not too far in the exercises, take time to recreate all files as mentioned in the tutorial so it helps you!
So that’s all ! Just focus more when you learn !
Best Regards,
This topic was automatically closed after 21 hours. New replies are no longer allowed.
