That is odd! Those above steps should work.
Here is my final modifications that I believe should work!
Modified CMakeLists.txt file for my_examples_pkg.
project(my_examples_pkg)
rospy
std_msgs
# catkin_python_setup()
## * In the file package.xml:
add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
#add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES my_examples_pkg
CATKIN_DEPENDS rospy std_msgs
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/my_examples_pkg.cpp
add_dependencies(my_custom_srv_msg_pkg ${catkin_EXPORTED_TARGETS})
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/my_examples_pkg_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_my_examples_pkg.cpp)
# endif()
# catkin_add_nosetests(test)
Modified package.xml file for my_examples_pkg.
<?xml version="1.0"?>
<package format="2">
<name>my_examples_pkg</name>
<version>0.0.0</version>
<description>The my_examples_pkg package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/my_examples_pkg</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<export>
</export>
</package>
These are modified based on this link: ROS/Tutorials/DefiningCustomMessages - ROS Wiki
If these steps do not work, then as a last resort, you must create the package from scratch.
Your problem is basically “How to use custom message from another ROS package”.
