I am learning unit4 “Feature Matching” - “OpenCV for Robotics”. I cannot really understand a part of code in despite of the comments. The whole code of process of feature matching in course book is shown as:
#!/usr/bin/env python
import cv2
import matplotlib.pyplot as plt
import numpy as np
image_1a = cv2.imread('/home/user/catkin_ws/src/opencv_for_robotics_images/Unit_4/Course_images/ROS.png',1)
image_2a = cv2.imread('/home/user/catkin_ws/src/opencv_for_robotics_images/Unit_4/Course_images/ROS2.jpg',1)
image_1 = cv2.resize(image_1a,(400,600))
image_2 = cv2.resize(image_2a,(600,400))
gray_1 = cv2.cvtColor(image_1, cv2.COLOR_RGB2GRAY)
gray_2 = cv2.cvtColor(image_2, cv2.COLOR_RGB2GRAY)
#Initialize the ORB Feature detector
orb = cv2.ORB_create(nfeatures = 1000)
#Make a copy of th eoriginal image to display the keypoints found by ORB
#This is just a representative
preview_1 = np.copy(image_1)
preview_2 = np.copy(image_2)
#Create another copy to display points only
dots = np.copy(image_1)
#Extract the keypoints from both images
train_keypoints, train_descriptor = orb.detectAndCompute(gray_1, None)
test_keypoints, test_descriptor = orb.detectAndCompute(gray_2, None)
#Draw the found Keypoints of the main image
cv2.drawKeypoints(image_1, train_keypoints, preview_1, flags = cv2.DRAW_MATCHES_FLAGS_DRAW_RICH_KEYPOINTS)
cv2.drawKeypoints(image_1, train_keypoints, dots, flags=2)
################## MATCHER ##################
#Initialize the BruteForce Matcher
bf = cv2.BFMatcher(cv2.NORM_HAMMING, crossCheck = True)
#Match the feature points from both images
matches = bf.match(train_descriptor, test_descriptor)
#The matches with shorter distance are the ones we want.
matches = sorted(matches, key = lambda x : x.distance)
#Catch some of the matching points to draw
good_matches = matches[:300]
#Parse the feature points
train_points = np.float32([train_keypoints[m.queryIdx].pt for m in good_matches]).reshape(-1,1,2)
test_points = np.float32([test_keypoints[m.trainIdx].pt for m in good_matches]).reshape(-1,1,2)
#Create a mask to catch the matching points
#With the homography we are trying to find perspectives between two planes
#Using the Non-deterministic RANSAC method
M, mask = cv2.findHomography(train_points, test_points, cv2.RANSAC,5.0)
#Catch the width and height from the main image
h,w = gray_1.shape[:2]
#Create a floating matrix for the new perspective
pts = np.float32([[0,0],[0,h-1],[w-1,h-1],[w-1,0] ]).reshape(-1,1,2)
#Create the perspective in the result
dst = cv2.perspectiveTransform(pts,M)
#Draw the matching lines
dots = cv2.drawMatches(dots,train_keypoints,image_2,test_keypoints,good_matches, None,flags=2)
# Draw the points of the new perspective in the result image (This is considered the bounding box)
result = cv2.polylines(image_2, [np.int32(dst)], True, (50,0,255),3, cv2.LINE_AA)
cv2.imshow('Points',preview_1)
cv2.imshow('Matches',dots)
cv2.imshow('Detection',result)
cv2.waitKey(0)
cv2.destroyAllWindows()
My questions are as followed:
1.
In these ines:
Why should we extract points in train_points with queryidx? And how can I know the exact inner structure of train_keypoint? It has attribute of pt as it shows above, but is there other attributes? I cannot find one in OpenCV documents, and print(train_points[0]) only return a general type.
2.
what does this part actually do? According to the theory, we should have a train point set and target point set, and find the homography matrix between them. But what exactly is the returned output M and mask? And what happened in details within pts and dst? The official document which I found from OpenCV explains still confused, could anyone share a more comprehensive explanation, both for thoery and for coding?
Thanks a lot
