Ssh error - Permission denied, please try again
here i am getting error while trying to build the rosbot. i tried from Linux system.
After loading rosbots image into the raspberry pi i am getting above ssh error.
please try to solve me the error as soon as possibe
Hi @durgaprasadf439b3bf90c74283,
make sure that your login credentials are correct and that ssh is enabled on your pi. Default user and passoword for rpi are:
pi
raspberry
so connecting via ssh you do like this:
ssh pi@[ip adress]
Hi, @simon.steinmann91 I downloaded the image i.e ROS+OpenCV Raspbian
which is mentioned in the course i.e Your First Robot with ROS
after that i tried with credentials are
pi
rosbots!
already SSH is enabled in the pi
Screenshots could help. Also, are you sure that ‘rosbots!’ is the password of your system? You might want to manually change or set it.
Thankyou @simon.steinmann91 for your response. Now I got the SSH connection
I tried with
sudo raspi-config
and changed the network to wifi
after that I got the SSH
