Stuck in running
I have implemented everything as instructed. I faced errors, but I built everything from the start. Again the same error is coming which is getting stuck in the terminal 3 and never getting executed as shown in the image.
Most likely, this isn’t a bug with the platform, but some problem in your code or workspace.
Unfortunately, I could not understand what you were trying to do from this post. Kindly:
  • Describe which example, exercise, or quiz you are trying to solve
  • What have you done to solve it?
  • What is working?
  • What is not working? What do you mean by “stuck”?
Please attach a screenshot clearly showing the error.
