Stuck on the service quiz
Hello Everyone,
I am stuck on the service quiz. I tried creating the srv file and changes in cMake and .XML file. Whenever I am trying to catkin_make in catkin_ws I am getting the following errors
CMake Error at /opt/ros/noetic/share/catkin/cmake/catkin_package.cmake:305 (message):
  catkin_package() include dir 'include' does not exist relative to
  '/home/user/catkin_ws/src/services_quiz'
  /opt/ros/noetic/share/catkin/cmake/catkin_package.cmake:102 (_catkin_package)
  services_quiz/CMakeLists.txt:104 (catkin_package)
-- Configuring incomplete, errors occurred!
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeError.log".
make: *** [Makefile:320: cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
here is my srv script ā€˜BB8CustomServiceMessage.srv’
float64 side
int32 repetitions
bool success
cMake File
project(services_quiz)
  rospy
  std_msgs
  message_generation
# catkin_python_setup()
##   your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
## * In the file package.xml:
##   * add a build_depend tag for "message_generation"
##   * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
##   * If MSG_DEP_SET isn't empty the following dependency has been pulled in
##     but can be declared for certainty nonetheless:
##     * add a exec_depend tag for "message_runtime"
##   * add "message_generation" and every package in MSG_DEP_SET to
##     find_package(catkin REQUIRED COMPONENTS ...)
##   * add "message_runtime" and every package in MSG_DEP_SET to
##     catkin_package(CATKIN_DEPENDS ...)
##   * uncomment the add_*_files sections below as needed
##     and list every .msg/.srv/.action file to be processed
##   * uncomment the generate_messages entry below
##   * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
# add_message_files(
#   FILES
#   Message1.msg
#   Message2.msg
 add_service_files(
   FILES
# add_action_files(
#   FILES
#   Action1.action
#   Action2.action
 generate_messages(
   DEPENDENCIES
   std_msgs  # Or other packages containing msgs
##   * add a build_depend and a exec_depend tag for "dynamic_reconfigure"
##   * add "dynamic_reconfigure" to
##   * uncomment the "generate_dynamic_reconfigure_options" section below
##     and list every .cfg file to be processed
#   cfg/DynReconf1.cfg
#   cfg/DynReconf2.cfg
catkin_package(
  INCLUDE_DIRS include
  LIBRARIES services_quiz
  CATKIN_DEPENDS
  rospy message_runtime
  DEPENDS system_lib
## Build ##
include_directories(
# include
  ${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
#   src/${PROJECT_NAME}/services_quiz.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/services_quiz_node.cpp)
#   ${catkin_LIBRARIES}
## Install ##
#   scripts/my_python_script
#   DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
#   DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
#   FILES_MATCHING PATTERN "*.h"
#   PATTERN ".svn" EXCLUDE
# install(FILES
#   # myfile1
#   # myfile2
#   DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_services_quiz.cpp)
#   target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
# endif()
# catkin_add_nosetests(test)
.XML file
<?xml version="1.0"?>
<package format="2">
  <name>services_quiz</name>
  <version>0.0.0</version>
  <description>The services_quiz package</description>
  <!-- Example:  -->
  <!--   BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
  <license>TODO</license>
  <!-- Example: -->
  <!-- <url type="website">http://wiki.ros.org/services_quiz</url> -->
  <!-- Example: -->
  <!-- Examples: -->
  <!--   <depend>roscpp</depend> -->
  <!--   Note that this is equivalent to the following: -->
  <!--   <build_depend>roscpp</build_depend> -->
  <!--   <exec_depend>roscpp</exec_depend> -->
  <!--   <build_depend>message_generation</build_depend> -->
  <!--   <build_export_depend>message_generation</build_export_depend> -->
  <!--   <buildtool_depend>catkin</buildtool_depend> -->
  <!--   <exec_depend>message_runtime</exec_depend> -->
  <!--   <test_depend>gtest</test_depend> -->
  <!--   <doc_depend>doxygen</doc_depend> -->
  <export>
  </export>
</package>
Any help on where I am going wrong?
Thank you.
Hi @Shhrekk ,
Welcome to the Community!
Your post is quite long, thus I also had to make my post fairly long!
  1. You have posted under ROS Basics in 5Days with Python, however, your very first CMake error states that you are missing ā€œincludeā€ directory, which is only available for C++ version. Are you sure you are on Python and not C++?
  2. Your BB8CustomServiceMessage.srv file is correct.
  3. Your CMake file requires few more dependencies:
    • You must include geometry_msgs under find_package to implement robot movement with Twist command
    • Your add_service_files is correct
    • Add geometry_msgs to generate_messages
    • Under catkin_package have only CATKIN_DEPENDS line uncommented, like below
    catkin_package(
    #INCLUDE_DIRS include
    #LIBRARIES services_quiz
      CATKIN_DEPENDS rospy geometry_msgs std_msgs
    #DEPENDS system_lib
  4. In the package.xml file you must add std_msgs and geometry_msgs under build_depend, build_export_depend, exec_depend.
  <build_depend>geometry_msgs</build_depend>
  <build_export_depend>geometry_msgs</build_export_depend>
  <exec_depend>geometry_msgs</exec_depend>
Summary: Basically, your setup procedure was not proper.
My advice: [Please] Go through the tutorial for compiling/setup again. Understand what changes to be made in CMakeLists.txt file and package.xml so you can successfully compile your program. If you go wrong, trace your steps back and recheck with the procedure. Do it a few times, next time it will come to you automatically!
Let me know if I helped you!
Cheers,
Thank You Girish,
I am doing the ROS Basics in 5 days(python) I had initially uncommented everything in catkin_package and as you pointed out just needed CATKIN_DEPENDS uncommented.
Additionally, I was under the misconception that if I create package with just 'catkin_create_pakage ā€˜Package name’ rospy ==>this includes all rospy packages which is why I had only put rospy in CATKIN_DEPEND and same in the .XML file
@Shhrekk ,
Glad that you got things working.
By the way, the catkin create command is
catkin_create_pkg <package_name>
And not
catkin_create_package <package_name>
