Suggestion for quiz results
In the quiz section after a solution has been submitted, it would be helpful if it showed correct / total. Mainly as I suspect that all green means good, but without any additional feedback I could have had something wrong, not realized it, clicked check submission and then be unable to resubmit again later if I had gotten anything incorrect and wanted to attempt to solve it again.
All of that said, if this already there and I was just unaware then please help me find out where the total points for a quiz might be located.
Thanks all!
Hello @gotbordom ,
If you try to submit again the Quiz for grading it will show you your current score like this:
Then, after you check the solution / run out of quiz attempts, you will be able to see the quiz results in the bottom bar:
Hope this helps,
