I reloaded the simulation during the exam. The robot is loaded but the web shell (terminal) didn’t load. It says “none’s server IP address could not be found”. I am in the middle of the exam now. What should I do? If I exit, can I retake the exam?
Finally, it got connected. After I reloaded it several times for about 15 minutes now. Thanks.
Hi @bhushanhurali,
I’m happy in the end it worked for you.
Please let us know in case this happens again.
