Test.action Not Found
In Exercise 9.13, the prompt recommends using the shell command:
find /opt/ros/kinetic/ -name Test.action
This returns an error:
find: '/opt/ros/kinetic/': No such file or directory
However, I found a solution by changing “kinetic” to “noetic”.
Solution:
find /opt/ros/noetic/ -name Test.action
I believe this is correct since the course is based in noetic. If an admin could make this change, it may reduce future confusion for students.
Thank you for letting us know. I have captured the bug in our tracker.
