the launch file:
import os
from launch.substitutions import LaunchConfiguration
from launch.actions import DeclareLaunchArgument
use_sim_time = LaunchConfiguration('use_sim_time', default='false')
log_level = LaunchConfiguration('log_level')
remappings = [('/tf', 'tf'), ('/tf_static', 'tf_static')]
nav2_bringup_dir = get_package_share_directory('nav2_bringup')
rviz_config = os.path.join(nav2_bringup_dir, 'rviz', 'nav2_default_view.rviz')
autostart = LaunchConfiguration('autostart')
fishbot2_yaml = os.path.join(get_package_share_directory('fishbot_navigation2'), 'config', 'nav2_params.yaml')
map_file = os.path.join(get_package_share_directory('fishbot_navigation2'), 'param', 'hhh.yaml')
return LaunchDescription([
DeclareLaunchArgument('log_level', default_value='info', description='log level'),
DeclareLaunchArgument('use_sim_time', default_value=use_sim_time, description='kys'),
DeclareLaunchArgument('autostart', default_value='true', description='Automatically startup the nav2 stack'),
Node(
package='nav2_map_server',
executable='map_server',
name='map_server',
output='screen',
{'yaml_filename':map_file}],
arguments=['--ros-args', '--log-level', log_level],
remappings=remappings
Node(
package='nav2_amcl',
executable='amcl',
name='amcl',
output='screen',
parameters=[fishbot2_yaml],
Node(
package='nav2_controller',
executable='controller_server',
name='controller_server',
output='screen',
remappings=remappings + [('cmd_vel', 'fishbot2/cmd_vel')]
Node(
package='nav2_smoother',
executable='smoother_server',
name='smoother_server',
output='screen',
Node(
package='nav2_planner',
executable='planner_server',
name='planner_server',
output='screen',
Node(
package='nav2_behaviors',
executable='behavior_server',
name='behavior_server',
output='screen',
Node(
package='nav2_bt_navigator',
executable='bt_navigator',
name='bt_navigator',
output='screen',
Node(
package='nav2_waypoint_follower',
executable='waypoint_follower',
name='waypoint_follower',
output='screen',
Node(
package='nav2_velocity_smoother',
executable='velocity_smoother',
name='velocity_smoother',
output='screen',
remappings=remappings + [('cmd_vel', 'fishbot2/cmd_vel'), ('cmd_vel_smoothed', 'fishbot2/cmd_vel')]
Node(
name='lifecycle_manager_localization',
output='screen',
parameters=[{'use_sim_time': use_sim_time},
{'autostart': autostart},
{'node_names': ['map_server', 'amcl']}]
Node(
name='lifecycle_manager_navigation',
output='screen',
{'node_names': ['controller_server', 'smoother_server', 'planner_server', 'behavior_server', 'bt_navigator', 'waypoint_follower', 'velocity_smoother']}]
Node(
package='rviz2',
executable='rviz2',
name='rviz2',
arguments=['-d', rviz_config],
parameters=[{'use_sim_time': use_sim_time}],
output='screen'
the params file:
amcl:
ros__parameters:
use_sim_time: True
alpha1: 0.2
alpha2: 0.2
alpha3: 0.2
alpha4: 0.2
alpha5: 0.2
base_frame_id: “fishbot2/base_footprint”
beam_skip_distance: 0.5
beam_skip_error_threshold: 0.9
beam_skip_threshold: 0.3
do_beamskip: false
global_frame_id: “map”
lambda_short: 0.1
laser_likelihood_max_dist: 2.0
laser_max_range: 100.0
laser_min_range: -1.0
laser_model_type: “likelihood_field”
max_beams: 60
max_particles: 2000
min_particles: 500
odom_frame_id: “fishbot2/odom”
pf_err: 0.05
pf_z: 0.99
recovery_alpha_fast: 0.0
recovery_alpha_slow: 0.0
resample_interval: 1
robot_model_type: “nav2_amcl::DifferentialMotionModel”
save_pose_rate: 0.5
sigma_hit: 0.2
tf_broadcast: true
transform_tolerance: 1.0
update_min_a: 0.2
update_min_d: 0.25
z_hit: 0.5
z_max: 0.05
z_rand: 0.5
z_short: 0.05
scan_topic: “/fishbot2/scan”
bt_navigator:
ros__parameters:
use_sim_time: True
global_frame: map
robot_base_frame: fishbot2/base_link
odom_topic: /fishbot2/odom
bt_loop_duration: 10
default_server_timeout: 20
# ‘default_nav_through_poses_bt_xml’ and ‘default_nav_to_pose_bt_xml’ are use defaults:
# nav2_bt_navigator/navigate_to_pose_w_replanning_and_recovery.xml
# nav2_bt_navigator/navigate_through_poses_w_replanning_and_recovery.xml
# They can be set here or via a RewrittenYaml remap from a parent launch file to Nav2.
plugin_lib_names:
- nav2_compute_path_through_poses_action_bt_node
- nav2_smooth_path_action_bt_node
- nav2_spin_action_bt_node
- nav2_wait_action_bt_node
- nav2_assisted_teleop_action_bt_node
- nav2_back_up_action_bt_node
- nav2_drive_on_heading_bt_node
- nav2_globally_updated_goal_condition_bt_node
- nav2_is_path_valid_condition_bt_node
- nav2_truncate_path_local_action_bt_node
- nav2_recovery_node_bt_node
- nav2_path_expiring_timer_condition
- nav2_single_trigger_bt_node
- nav2_goal_updated_controller_bt_node
- nav2_is_battery_low_condition_bt_node
- nav2_navigate_through_poses_action_bt_node
- nav2_navigate_to_pose_action_bt_node
- nav2_remove_passed_goals_action_bt_node
- nav2_planner_selector_bt_node
- nav2_controller_selector_bt_node
- nav2_goal_checker_selector_bt_node
- nav2_controller_cancel_bt_node
- nav2_path_longer_on_approach_bt_node
- nav2_wait_cancel_bt_node
- nav2_spin_cancel_bt_node
- nav2_back_up_cancel_bt_node
- nav2_assisted_teleop_cancel_bt_node
- nav2_drive_on_heading_cancel_bt_node
- nav2_is_battery_charging_condition_bt_node
bt_navigator_navigate_through_poses_rclcpp_node:
ros__parameters:
use_sim_time: True
bt_navigator_navigate_to_pose_rclcpp_node:
ros__parameters:
use_sim_time: True
controller_server:
ros__parameters:
use_sim_time: True
controller_frequency: 20.0
min_y_velocity_threshold: 0.5
failure_tolerance: 0.3
progress_checker_plugin: “progress_checker”
goal_checker_plugins: [“general_goal_checker”] # “precise_goal_checker”
controller_plugins: [“FollowPath”]
# Progress checker parameters
progress_checker:
required_movement_radius: 0.5
movement_time_allowance: 10.0
# Goal checker parameters
#precise_goal_checker:
# plugin: "nav2_controller::SimpleGoalChecker"
# xy_goal_tolerance: 0.25
# yaw_goal_tolerance: 0.25
# stateful: True
general_goal_checker:
stateful: True
# DWB parameters
FollowPath:
min_vel_x: 0.0
min_vel_y: 0.0
max_vel_x: 0.26
max_vel_y: 0.0
max_vel_theta: 1.0
min_speed_xy: 0.0
max_speed_xy: 0.26
min_speed_theta: 0.0
# Add high threshold velocity for turtlebot 3 issue.
# https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
acc_lim_x: 2.5
acc_lim_y: 0.0
acc_lim_theta: 3.2
decel_lim_x: -2.5
decel_lim_y: 0.0
decel_lim_theta: -3.2
vx_samples: 20
vy_samples: 5
vtheta_samples: 20
sim_time: 1.7
linear_granularity: 0.05
angular_granularity: 0.025
transform_tolerance: 0.2
trans_stopped_velocity: 0.25
stateful: True
BaseObstacle.scale: 0.02
PathAlign.scale: 32.0
GoalAlign.scale: 24.0
PathDist.scale: 32.0
GoalDist.scale: 24.0
RotateToGoal.scale: 32.0
local_costmap:
local_costmap:
ros__parameters:
update_frequency: 5.0
publish_frequency: 2.0
global_frame: fishbot2/odom
use_sim_time: True
rolling_window: true
width: 3
height: 3
resolution: 0.05
robot_radius: 0.08
plugins: [“voxel_layer”, “inflation_layer”]
inflation_layer:
plugin: “nav2_costmap_2d::InflationLayer”
cost_scaling_factor: 3.0
inflation_radius: 0.55
voxel_layer:
plugin: “nav2_costmap_2d::VoxelLayer”
enabled: True
publish_voxel_map: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
max_obstacle_height: 2.0
mark_threshold: 0
observation_sources: scan
scan:
topic: /fishbot2/scan
clearing: True
marking: True
data_type: “LaserScan”
raytrace_max_range: 3.0
raytrace_min_range: 0.0
obstacle_max_range: 2.5
obstacle_min_range: 0.0
static_layer:
plugin: “nav2_costmap_2d::StaticLayer”
map_subscribe_transient_local: True
always_send_full_costmap: True
global_costmap:
global_costmap:
ros__parameters:
update_frequency: 1.0
publish_frequency: 1.0
global_frame: map
use_sim_time: True
robot_radius: 0.08
resolution: 0.05
track_unknown_space: true
plugins: [“static_layer”, “obstacle_layer”, “inflation_layer”]
obstacle_layer:
plugin: “nav2_costmap_2d::ObstacleLayer”
enabled: True
scan:
clearing: True
marking: True
static_layer:
inflation_layer:
map_server:
ros__parameters:
use_sim_time: True
# Overridden in launch by the “map” launch configuration or provided default value.
# To use in yaml, remove the default “map” value in the tb3_simulation_launch.py file & provide full path to map below.
yaml_filename: “”
map_saver:
ros__parameters:
use_sim_time: True
save_map_timeout: 5.0
free_thresh_default: 0.25
occupied_thresh_default: 0.65
planner_server:
ros__parameters:
expected_planner_frequency: 20.0
use_sim_time: True
planner_plugins: [“GridBased”]
GridBased:
plugin: “nav2_navfn_planner/NavfnPlanner”
tolerance: 0.5
use_astar: false
allow_unknown: true
smoother_server:
ros__parameters:
use_sim_time: True
smoother_plugins: [“simple_smoother”]
simple_smoother:
plugin: “nav2_smoother::SimpleSmoother”
tolerance: 1.0e-10
max_its: 1000
do_refinement: True
behavior_server:
ros__parameters:
costmap_topic: local_costmap/costmap_raw
footprint_topic: local_costmap/published_footprint
cycle_frequency: 10.0
behavior_plugins: [“spin”, “backup”, “drive_on_heading”, “assisted_teleop”, “wait”]
spin:
plugin: “nav2_behaviors/Spin”
backup:
plugin: “nav2_behaviors/BackUp”
drive_on_heading:
plugin: “nav2_behaviors/DriveOnHeading”
wait:
plugin: “nav2_behaviors/Wait”
assisted_teleop:
plugin: “nav2_behaviors/AssistedTeleop”
transform_tolerance: 0.1
use_sim_time: true
simulate_ahead_time: 2.0
max_rotational_vel: 1.0
min_rotational_vel: 0.4
rotational_acc_lim: 3.2
robot_state_publisher:
ros__parameters:
use_sim_time: True
waypoint_follower:
ros__parameters:
use_sim_time: True
loop_rate: 20
stop_on_failure: false
waypoint_task_executor_plugin: “wait_at_waypoint”
wait_at_waypoint:
plugin: “nav2_waypoint_follower::WaitAtWaypoint”
enabled: True
waypoint_pause_duration: 200
velocity_smoother:
ros__parameters:
use_sim_time: True
smoothing_frequency: 20.0
scale_velocities: False
feedback: “OPEN_LOOP”
max_velocity: [0.26, 0.0, 1.0]
min_velocity: [-0.26, 0.0, -1.0]
max_accel: [2.5, 0.0, 3.2]
max_decel: [-2.5, 0.0, -3.2]
odom_topic: “fishbot2/odom”
odom_duration: 0.1
deadband_velocity: [0.0, 0.0, 0.0]
velocity_timeout: 1.0
