The broken .bashrc
Hi, I’m following the tutorial. When I opened the .bashrc for first time, I tried to look all the commands and then I accidently writing/typing something. After that whole .bashrc code got changed. I tried to open the course again, restart the computer but It didn’t restored.It also says that “This file will be saved together with your rosject.” How can I fix this?
# scrubbed
Most Linux distributions come with a default .bashrc file that can be copied back into the home directory. To restore this file, they can use the following command:
cp /etc/skel/.bashrc ~/.bashrc
@z.baysal
We can provide you the default ~/.bashrc for The Construct. Please note that, ideally, you should not make changes to this file unless asked to, and you should only make the changes asked.
@merajhossainpromit
Thanks for trying to help out, but the default .bashrc might not work out of the box. You need to use the one provided by The Construct.
Here you have the original .bashrc:
# ~/.bashrc: executed by bash(1) for non-login shells.
# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
# for examples
# When running commands through Python's Popen or Python's SSH Client (paramiko)
# the shells are not interactive and "source /home/user/.bash_aliases" is not
# executed. Because of that our scripts fails for not having ROS_* variables
# defined. Since we always need those variables, no matter whether we are using
# ssh or python, we uncomment the lines below.
# It is worth mentioning also that when running commands with
#   sudo su user -c "echo commands executed by the 'user' user"
# the ~/.bashrc is not called. In those cases we have to explicitly call
#   source ~/.bashrc
# More details on PR #122.
# # If not running interactively, don't do anything
# case $- in
#    *i*) ;;
#      *) return;;
# esac
# After we disabled the "return" above the course tests started failing because
# we have "set -e" and the /usr/share/bash-completion/bash_completion fails.
# Let's them disable the "set -e" if it is enabled.
tc__exit_on_error=false
if shopt -po errexit > /dev/null; then
    tc__exit_on_error=true;
    set +e
fi
# don't put duplicate lines or lines starting with space in the history.
# See bash(1) for more options
HISTCONTROL=ignoreboth
# append to the history file, don't overwrite it
shopt -s histappend
# for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
HISTSIZE=1000
HISTFILESIZE=2000
# check the window size after each command and, if necessary,
# update the values of LINES and COLUMNS.
shopt -s checkwinsize
# If set, the pattern "**" used in a pathname expansion context will
# match all files and zero or more directories and subdirectories.
#shopt -s globstar
# make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
    debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
    xterm-color) color_prompt=yes;;
esac
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
#force_color_prompt=yes
if [ -n "$force_color_prompt" ]; then
    if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
        # We have color support; assume it's compliant with Ecma-48
        # (ISO/IEC-6429). (Lack of such support is extremely rare, and such
        # a case would tend to support setf rather than setaf.)
        color_prompt=yes
    else
        color_prompt=
    fi
fi
if [ "$color_prompt" = yes ]; then
    PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
    PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
fi
unset color_prompt force_color_prompt
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*)
    PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
esac
# enable color support of ls and also add handy aliases
if [ -x /usr/bin/dircolors ]; then
    test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
    alias ls='ls --color=auto'
    #alias dir='dir --color=auto'
    #alias vdir='vdir --color=auto'
    alias grep='grep --color=auto'
    alias fgrep='fgrep --color=auto'
    alias egrep='egrep --color=auto'
fi
# some more ls aliases
alias ll='ls -alF'
alias la='ls -A'
alias l='ls -CF'
# Add an "alert" alias for long running commands.  Use like so:
#   sleep 10; alert
alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\'')"'
# Alias definitions.
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
# See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then
    . ~/.bash_aliases
fi
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if ! shopt -oq posix; then
  if [ -f /usr/share/bash-completion/bash_completion ]; then
    . /usr/share/bash-completion/bash_completion
  elif [ -f /etc/bash_completion ]; then
    . /etc/bash_completion
  fi
fi
# If we from The Construct disabled "set -e", let's enable it again.
if  [[ "${tc__exit_on_error}" == "true" ]]; then set -e; fi
unset tc__exit_on_error
#           Note from The Construct
# This file will be saved together with your rosject.
# Add your custom exports at the end of this file. E.g.:
#   export MY_SETTING=value
#   export GAZEBO_RESOURCE_PATH=$GAZEBO_RESOURCE_PATH:/home/user/simulation_ws/src/my_package
