The meaning of manually written "multiple_broadcaster.py"
I am doing “3 Publisch & Subscribe to TF data” of “TF” course. In this case we are learning how to write a py-file to broadcast/publish TF data. But I find that even though without this manually written py-file, we can still see turtle1 and turtle2 in rqt_tf_tree and rviz.
If we add “coke_can” in name_list in this py-file, rqt_tf_tree will add “coke_can” as well. But why “turtle1” and “turtle2” always show themselves? Where has this defined? Even though I set the name_list in “multiple_broadcaster.py” just as [“coke_can”], “turtle1” and “turtle2” remain. As a result, what is the meaning of this manually written “multiple_broadcaster.py”? Just add ‘‘other’’ objects to present?
The manually written “multiple_broadcaster.py” is here:
import time
import tf
from turtle_tf_3d.get_model_gazebo_pose import GazeboModel
class MultiTfBroadcast(object):
def __init__(self, robot_name_list, loop_rate=5.0):
    self._robot_name_list = robot_name_list
    self._gazebo_model_object = GazeboModel(self._robot_name_list)
    # hz
    self._rate = rospy.Rate(loop_rate)
    # We start the Tf broadcaster
    self._broad_caster_tf = tf.TransformBroadcaster()
    # Leave enough time to be sure the Gazebo Model logs have finished
    time.sleep(1)
    rospy.loginfo("Ready..Starting to Publish TF data now...")
def handle_turtle_pose(self, pose_msg, robot_name, reference_frame_data="/world"):
    self._broad_caster_tf.sendTransform((pose_msg.position.x, pose_msg.position.y, pose_msg.position.z),
                                        (pose_msg.orientation.x, pose_msg.orientation.y,
                                         pose_msg.orientation.z, pose_msg.orientation.w),
                                        rospy.Time.now(),
                                        robot_name,
                                        reference_frame_data)
def start_loop(self):
        for robot_name in self._robot_name_list:
            pose_now = self._gazebo_model_object.get_model_pose(robot_name)
            if not pose_now:
                robot_name_msg = "The " + \
                    str(robot_name) + \
                    "'s Pose is not yet available...Please try again later"
                rospy.loginfo(robot_name_msg)
            else:
                self.handle_turtle_pose(pose_now, robot_name)
        self._rate.sleep()
def main():
rospy.init_node('publisher_of_tf_node', anonymous=True)
multi_tf_broadcast_obj = MultiTfBroadcast(
    robot_name_list=["turtle1", "turtle2", "coke_can"])
try:
    multi_tf_broadcast_obj.start_loop()
    pass
if name == ‘main’:
main()
Hello @MeineLiebeAxt,
as I understand from you post you are executing the multiple_broadcaster.py script after having modified this line here:
    robot_name_list=["turtle1", "turtle2"])
into this:
    robot_name_list=["coke_can"])
and you are wondering why in the new version of your multiple_broadcaster.py file the TF’s for turtle1 and turtle2 are also being published. Did I understand your question correctly?
The answer is they should not be published. So something else must be causing this issue.
To start, please confirm a few things:
  • You have saved your new multiple_broadcaster.py script and the line above is like so:
  • You have stopped all ROS nodes running in every Webshell before you run you new code. To do so switch to every Webshell and press Ctrl + C.
  • Confirm that when you execute the script you see these lines printed out to the console:
user:~/catkin_ws/src/tf_exercises_pkg$ rosrun tf_exercises_pkg multiple_broadcaster.py
[INFO] [1665562839.223504, 0.000000]: Retrieveing Model indexes
[INFO] [1665562839.256574, 481.781000]: Final robots_index_dict =  {'coke_can': 1}
[INFO] [1665562840.266317, 482.797000]: Ready..Starting to Publish TF data now...
The second INFO log shows the name of the objects who’s TF’s will be broadcasted in lines above it is just coke_can. In that case you should only see the TF for coke_can being published.
Hope this helps,
Roberto
