I’m following the Python for Robotics course and I’m woorking on Unit 4 - Methods. But when I take a look at the robot_control_class.py I see many time the argument self appearing. I’m trying to understand this. I have read another topic here where I saw a small explanation but I’m not sure if I understand it correct so I try to get the confirmation in this topic.
A small snippet of the robot_control_class.py is below.
def __init__(self, robot_name="turtlebot"):
rospy.init_node('robot_control_node', anonymous=True)
if robot_name == "summit":
rospy.loginfo("Robot Summit...")
cmd_vel_topic = "/summit_xl_control/cmd_vel"
# We check that sensors are working
self._check_summit_laser_ready()
else:
rospy.loginfo("Robot Turtlebot...")
cmd_vel_topic='/cmd_vel'
self._check_laser_ready()
# We start the publisher
self.vel_publisher = rospy.Publisher(cmd_vel_topic, Twist, queue_size=1)
self.cmd = Twist()
self.laser_subscriber = rospy.Subscriber(
'/kobuki/laser/scan', LaserScan, self.laser_callback)
self.summit_laser_subscriber = rospy.Subscriber(
'/hokuyo_base/scan', LaserScan, self.summit_laser_callback)
self.ctrl_c = False
self.rate = rospy.Rate(1)
So now if I create a script and import the class and instantiate it as follows:
rc = RobotControl()
disValues = rc.get_laser_full()
maximum = 0
for dis in disValues:
if dis > maximum:
maximum = dis
print("Maximum distance is:", maximum)
Does the argument `self` basically says that I refer to the variable `rc`?
Thanks in advance
