Yes, I tried the ‘Reconnect’ button on the pink error message. A little indicator would spin for between 15 and 45 seconds. Then the pink error would show up or it would go straight to the back screen until I either:
Pushed the ‘Restart simulator’ button
or logged out and back in.
It stopped working for a couple of hours. It worked intermittently for about an hour. Then it started working again.
If it helps understand the issue, the system was particularly slow yesterday mid-day (in the US). It was taking 45 seconds to compile a small package that took less than 15 seconds earlier in the day.
I was doing some experimenting with how fast I could set the velocity on my robot and still slow down enough not to hit anything before it turned. So I did a bunch of ‘restart the simulator’ rather than just ‘reset the robot’ because a collision meant bumping the obstacle out of place. That might have registered as an unusually heavy system load.
I have a 300Mbps symmetrical fiber internet connection so connectivity should not be a problem at my end. I am willing to check in to logs on my end if it would help.
