The bot seems to be stuck since yesterday evening (I did try moving it into position but it doesn’t budge with keyboard or even gamepad inputs), my first time connecting to a real robot, idk who to approach for this.
Stuck for me too. Moving the joystick didn’t work.
Edit 1: I can see some movement on the wheels when using the joystick, so I think the bot has run over something that has it high-centered. It needs someone to physically reset it.
Yes, still stuck. I also saw the wheel rotating when using the joystick, but the bot did not move successfully.
Apologies for that glitch. This is fixed now.
