There is no specification on how the client should send the request
When I test my code it works fine, it exit at the end of the movement and everything. I assumed that the client send the request from the command using the argv like in previous examples. is this not the case?
this is the error I get:
:heavy_multiplication_x: [14:33:29] [assess] The robot did NOT fully perform the expected turn. ‘What do I do now?’:
  • Did the robot turn as indicated in the notebook?
  • Did the robot complete the turn within the stipulated time? (mark: 7.0)
@Deanaviv
I’m sorry that you ran into this issue. Let’s look into that for you.
Hi @Deanaviv ,
To test this specific step, the auto corrector runs the following commands:
  1. Launch the service server:
    ros2 launch services_quiz services_quiz_server.launch.py
  2. Launch the service client:
    ros2 launch services_quiz services_quiz_client.launch.py
So you should make sure when you run these commands the expected behavior is obtained.
