Threading Across Multiple Nodes ROS1 C++
I am currently working on the finishing touches of the rosject associated with the ROS Basics in 5 Days (C++). However, my action server client callbacks are not executing as intended. I believe it is a threading issue, but my research and debugging attempts have not yielded results.
I have 3 nodes with a launch file that launches all 3.
  • find_wall.cpp (service server)
  • follow_wall.cpp (service client, action client, basic subscriber/publisher)
  • record_odom.cpp (action server)
follow_wall should wait for the find_wall service to finish, then call the record_odom server, then perform a subscriber/publisher callback that navigates the robot around the room. As the robot is traveling around the room (laser_Callback), feedbackCb() should also be printing the total distance traveled and doneCb() should execute at the end of the lap when a result is returned.
I have tried creating asynchronous spinners and multithreaded spinners to no avail.
Please let me know how to coordinate callbacks between follow_wall.cpp and record_odom.cpp. Thank you!
find_wall.cpp:
#include "ros/duration.h"
#include "ros/init.h"
#include "ros/rate.h"
#include "ros/ros.h"
#include "geometry_msgs/Twist.h"
#include "rosject/FindWall.h"
#include <bits/stdc++.h>
#include <sensor_msgs/LaserScan.h>
class controller {
    public:
        controller(){
            pub = nh.advertise<geometry_msgs::Twist>("cmd_vel", 10);
            sub = nh.subscribe("/scan", 10, &controller::laserCallback, this);
            my_service = nh.advertiseService("/find_wall", &controller::find_Callback, this);
        void laserCallback(const sensor_msgs::LaserScan::ConstPtr& msg)
            // Identify which laser ray is the shortest one. Assume that this is the one pointing to a wall.
            laser_readings.clear();
            // creating vector of laser distances
            for (int i = 0; i < msg -> ranges.size(); i++) {
                laser_readings.push_back(msg -> ranges[i]);
        bool find_Callback(rosject::FindWall::Request  &req,
                           rosject::FindWall::Response &res)
            ROS_INFO("find_Callback has been called"); // We print an string whenever the Service gets called
            // Rotate the robot until the front of it is facing the wall. This can be done by publishing an angular velocity until front ray is the smallest one.
            status_update = "Rotating to face wall.";
            ROS_INFO("%s\n", status_update.c_str());
            while((laser_min < 359) || (laser_min > 361)){
                // finding index of min value in vector
                laser_min = distance(laser_readings.begin(), min_element(laser_readings.begin(),laser_readings.end()));
                if (laser_min > 360){
                    // if wall on the left, turn left
                    vel.angular.z = 0.1;
                } else if (laser_min < 360){
                    // if wall on the right, turn right
                    vel.angular.z = -0.1;
                } else {
                    // if facing wall, stop
                    vel.angular.z = 0;
                pub.publish(vel);
                ros::spinOnce();
            // Move the robot forward until the front ray is smaller than 30cm.
            vel.angular.z = 0;
            vel.linear.x = 0.1;
            pub.publish(vel);
            ROS_INFO("\n Min Element = %d", laser_min);
            status_update = "Moving toward wall.";
            while(laser_readings[360] > 0.3){
                ros::spinOnce();
            // Now rotate the robot again until ray number 270 of the laser ranges is pointing to the wall.
            vel.linear.x = 0;
            pub.publish(vel);
            status_update = "Turning parallel with wall.";
            while((laser_min < 269) || (laser_min > 271)){
                ros::spinOnce();
            // stop robot, ready for follow_wall
            vel.angular.z = 0;
            vel.linear.x = 0;
            pub.publish(vel);
            status_update = "In position for follow_wall.";
            // At this point, consider that the robot is ready to start following the wall.
            // Return the service message with True.
            ROS_INFO("find_Callback completed");
            res.wallfound = true;
            return true;
    private:
        ros::Subscriber sub;
        ros::Publisher pub;
        ros::NodeHandle nh;
        ros::ServiceServer my_service;
        std::string status_update;
        geometry_msgs::Twist vel;
        std::vector<float> laser_readings;
        int laser_min;
int main(int argc, char **argv)
  ros::init(argc, argv, "find_wall");
  controller ctrl;
  ros::spin();
  return 0;
follow_wall.cpp
#include "ros/publisher.h"
#include <ros/ros.h>
#include <iostream>
#include <string>
#include <geometry_msgs/Twist.h>
#include <stdlib.h>
#include <rosject/OdomRecordAction.h>
#include <actionlib/client/simple_action_client.h>
class controller {
    public:
        controller(): nh(), spinner(0){
        spinner.start();
        ros::service::waitForService("/find_wall");  // wait for service to be running
        ros::ServiceClient find_wall_service = nh.serviceClient<rosject::FindWall>("/find_wall");
        rosject::FindWall srv; // Create an object of type srv
        while(find_wall_service.call(srv) == false){
            ROS_INFO("Failure calling service /find_wall");
        ROS_INFO("Successfully called service /find_wall");
        // call action server to start recording odom values
        actionlib::SimpleActionClient<rosject::OdomRecordAction> client("record_odom", true);
        client.waitForServer(); // Waits until the action server is up and running
        rosject::OdomRecordGoal goal; // Creates a goal to send to the action server
        goal.success = false; // Fills the goal. Indicates, take pictures along 10 seconds
        client.sendGoal(goal, // sends the goal to the action server
                boost::bind(&controller::doneCb, this, _1, _2),
                boost::bind(&controller::activeCb, this),
                boost::bind(&controller::feedbackCb, this, _1));
        sub = nh.subscribe("/scan", 1000, &controller::laserCallback, this);
        pub = nh.advertise<geometry_msgs::Twist>("cmd_vel", 1000);
        vel.angular.z = 0;
        void doneCb(const actionlib::SimpleClientGoalState& state,
                    const rosject::OdomRecordResultConstPtr& result)
            ROS_INFO("The robot has completed a lap! Great job, robot.");
            ROS_INFO("The robot started at x = %f, y = %f, and theta = %f", result->list_of_odoms[0].x, result->list_of_odoms[0].y, result->list_of_odoms[0].z);
            int final = result -> list_of_odoms.size();
            //using final as index, so need to reduce by 1 since c++ indexing starts at 0.
            final -= 1;
            ROS_INFO("The robot started at x = %f, y = %f, and theta = %f", result->list_of_odoms[final].x, result->list_of_odoms[final].y, result->list_of_odoms[final].z);
            ros::shutdown();
        void activeCb()
            ROS_INFO("Odom values are now being recorded.");
        void feedbackCb(const rosject::OdomRecordFeedbackConstPtr& feedback)
            ROS_INFO("[Feedback] The robot has traveled %f meters.", feedback->current_total);
            mylocation = msg -> ranges[180];
            vel.linear.x = 0.1;
            //continue straight
            if (mylocation > 0.2 and mylocation < 0.3) {
                vel.angular.z = 0;
                status_update = "straight";
            //turn left to move away from the wall
            if (mylocation < 0.2 ) {
                vel.angular.z = 0.14;
                status_update = "away_from";
            //turn right to move closer to the wall
            if (mylocation > 0.3 ) {
                status_update = "to";
            // turn left if wall ahead
            if (msg -> ranges[360] < 0.7 ) {
                vel.angular.z = 0.4;
                status_update = "corner";
            //ROS_INFO("%f\n", mylocation);
            pub.publish(vel);
            //ros::spinOnce();
    private:
        ros::Publisher pub;
        ros::NodeHandle nh;
        double mylocation;
        ros::AsyncSpinner spinner;
int main(int argc, char** argv) {
    ros::init(argc, argv, "follow_wall");
    controller ctrl;
    ros::waitForShutdown();
    //spinner.spin();
    //ros::spin();
    return 0;
record_odom.cpp
#include <actionlib/server/simple_action_server.h>
#include <std_msgs/Empty.h>
#include <string>
#include <nav_msgs/Odometry.h>
#include <geometry_msgs/Point32.h>
class recordOdom
protected:
  ros::NodeHandle nh_;
  // NodeHandle instance must be created before this line. Otherwise strange error occurs.
  actionlib::SimpleActionServer<rosject::OdomRecordAction> as_;
  std::string action_name_;
  // create messages that are used to publish feedback and result
  rosject::OdomRecordFeedback feedback_;
  rosject::OdomRecordResult result_;
  ros::Subscriber odom;
  float calculatedDistance;
  float totalDistance = 0;
  float startDistance;
  int i = 0;
  geometry_msgs::Point32 coords;
  bool exit;
  bool enter;
public:
  recordOdom(std::string name):
    nh_(),
    spinner(0),
    as_(nh_, name, boost::bind(&recordOdom::executeCB,this,_1), false),
    action_name_(name)
    spinner.start();
    odom = nh_.subscribe("/odom", 10, &recordOdom::odomCallback, this);
    as_.start();
  ~recordOdom(void)
  float calculateDistance(float x1, float y1, float x2, float y2){
    return sqrt(pow(x2 - x1, 2) + pow(y2 - y1, 2));
  void odomCallback(const nav_msgs::Odometry::ConstPtr &msg)
    coords.x = msg -> pose.pose.position.x;
    coords.y = msg -> pose.pose.position.y;
    coords.z = msg -> pose.pose.orientation.w;
  void executeCB(const rosject::OdomRecordGoalConstPtr &goal)
    // helper variables
    ros::Rate r(1);
    bool success_;
    exit = false;
    enter = false;
    while(!enter){
        // check that preempt has not been requested by the client
        if (as_.isPreemptRequested() || !ros::ok())
            ROS_INFO("%s: Preempted", action_name_.c_str());
            // set the action state to preempted
            as_.setPreempted();
            success_ = false;
            break;
        result_.list_of_odoms.push_back(coords);
        // new point - previous point = distance traveled since last sub call
        // increment onto totalDistance
        if(i > 0){
            totalDistance += calculateDistance(result_.list_of_odoms[i-1].x,result_.list_of_odoms[i-1].y,result_.list_of_odoms[i].x, result_.list_of_odoms[i].y);
        // distance from the starting point
        startDistance = calculateDistance(result_.list_of_odoms[0].x,result_.list_of_odoms[0].y,result_.list_of_odoms[i].x, result_.list_of_odoms[i].y);
        // has the robot left the starting zone?
        if(startDistance > 0.5){
            // leaves the starting zone
            exit = true;
        // has the robot left the starting zone before and is now back within the starting zone?
        if((exit == true) && (startDistance < 0.5)){
            // reenters the starting zone - lap complete!
            enter = true;
        feedback_.current_total = totalDistance;
        as_.publishFeedback(feedback_);
        i += 1;
        ros::spinOnce();
        r.sleep();
    if(success_)
      ROS_INFO("%s: Succeeded", action_name_.c_str());
      as_.setSucceeded(result_);
  ros::init(argc, argv, "record_odom");
  recordOdom rOdom("record_odom");
  return 0;
Hi @IMSETraining
  • When you compile server action and action client, what appears on shells?
Remember that when you use multithreading it is not for controlling multiple nodes, but for multiple callbacks
 ros::AsyncSpinner spinner(0); //number of threads
 spinner.start();
 //callbacks u want to control
@Voltedge thank you for your response. The shell response upon compilation is below. I understand multithreading is utilized within each node. Am I utilizing it incorrectly within follow_wall.cpp?
user:~/catkin_ws$ catkin_make
#### Running command: "make cmake_check_build_system" in "/home/user/catkin_ws/build"
#### Running command: "make -j8 -l8" in "/home/user/catkin_ws/build"
[  0%] Built target geometry_msgs_generate_messages_eus
[  0%] Built target geometry_msgs_generate_messages_py
[  0%] Built target geometry_msgs_generate_messages_cpp
[  0%] Built target rosgraph_msgs_generate_messages_py
[  0%] Built target geometry_msgs_generate_messages_nodejs
[  0%] Built target rosgraph_msgs_generate_messages_lisp
[  0%] Built target rosgraph_msgs_generate_messages_cpp
[  0%] Built target rosgraph_msgs_generate_messages_eus
[  0%] Built target std_msgs_generate_messages_cpp
[  0%] Built target actionlib_msgs_generate_messages_eus
[  0%] Built target std_msgs_generate_messages_eus
[  0%] Built target roscpp_generate_messages_nodejs
[  0%] Built target actionlib_generate_messages_py
[  0%] Built target actionlib_msgs_generate_messages_nodejs
[  0%] Built target geometry_msgs_generate_messages_lisp
[  0%] Built target actionlib_generate_messages_lisp
[  0%] Built target roscpp_generate_messages_py
[  0%] Built target std_msgs_generate_messages_py
[  0%] Built target std_msgs_generate_messages_lisp
[  0%] Built target roscpp_generate_messages_eus
[  0%] Built target roscpp_generate_messages_cpp
[  0%] Built target roscpp_generate_messages_lisp
[  0%] Built target actionlib_generate_messages_eus
[  0%] Built target actionlib_generate_messages_cpp
[  0%] Built target actionlib_msgs_generate_messages_cpp
[  0%] Built target rosgraph_msgs_generate_messages_nodejs
[  0%] Built target actionlib_msgs_generate_messages_py
[  0%] Built target actionlib_msgs_generate_messages_lisp
[  0%] Built target actionlib_generate_messages_nodejs
[  0%] Built target std_msgs_generate_messages_nodejs
[  0%] Built target _rosject_generate_messages_check_deps_OdomRecordActionResult
[  0%] Built target _rosject_generate_messages_check_deps_FindWall
[  0%] Built target _rosject_generate_messages_check_deps_OdomRecordFeedback
Scanning dependencies of target follow_wall
[  2%] Building CXX object rosject/CMakeFiles/follow_wall.dir/src/follow_wall.cpp.o
[  2%] Built target _rosject_generate_messages_check_deps_OdomRecordResult
[  6%] Built target find_wall
[  6%] Built target _rosject_generate_messages_check_deps_OdomRecordActionGoal
[  6%] Built target _rosject_generate_messages_check_deps_OdomRecordGoal
[ 10%] Built target record_odom
[ 10%] Built target _rosject_generate_messages_check_deps_OdomRecordActionFeedback
[ 28%] Built target rosject_generate_messages_eus
[ 44%] Built target rosject_generate_messages_lisp
[ 61%] Built target rosject_generate_messages_cpp
[ 77%] Built target rosject_generate_messages_nodejs
[ 97%] Built target rosject_generate_messages_py
[100%] Linking CXX executable /home/user/catkin_ws/devel/lib/rosject/follow_wall
[100%] Built target follow_wall
I experimented with the location of ros::waitForShutdown() and the program started working as intended. I moved it within the class at the end of the constructor. This makes sense because the spinner is initialized at the beginning of the constructor and not the main function.
Updated follow_wall.cpp:
#include <iostream>
#include <string>
#include <stdlib.h>
class controller {
    public:
        controller():
        nh(),
        spinner(0){
        spinner.start();
        vel.angular.z = 0;
        ros::waitForShutdown(); //<--- Moved waitForShutdown to here.
            final -= 1;
            ROS_INFO("The robot finished at x = %f, y = %f, and theta = %f", result->list_of_odoms[final].x, result->list_of_odoms[final].y, result->list_of_odoms[final].z);
            vel.linear.x = 0;
            vel.angular.z = 0;
            pub.publish(vel);
            ros::shutdown();
        void activeCb()
            vel.linear.x = 0.1;
            //continue straight
                vel.angular.z = 0;
                status_update = "Moving straight forward.";
                status_update = "Moving away from the wall.";
                status_update = "Moving toward the wall.";
                status_update = "Corner ahead...turning...";
            pub.publish(vel);
            ros::spinOnce();
    private:
        ros::Publisher pub;
        ros::NodeHandle nh;
        double mylocation;
    controller ctrl;
    return 0;
Hi @IMSETraining
Exactly!
I’m glad I helped you
Oh and I think that the solution is this:
Threading Across Multiple Nodes ROS1 C++ - #2 by Voltedge :eyes:
