The topic of this question is the error I am receiving.
I am typing a program which runs the ACTION Server while the robot does a task of wall following. I am not sure why the state of action is at ‘2’ while it should remain in state ‘Active’ or ‘1’ until pre-empted to return a result.
I am not sure even I understand my question.
I am leaving out the import section.
The program below is for the client.
#service calling program
import actionlib
from rosject.srv import findwall, findwallRequest
from rosject.msg import OdomRecordActionFeedback, OdomRecordActionResult, OdomRecordActionGoal, OdomRecordAction
rospy.init_node('projectcall')
rospy.wait_for_service('/find_wall')
service_variable = rospy.ServiceProxy('/find_wall', findwall)
obj = findwallRequest()
result = service_variable(obj)
rospy.loginfo('Service FindWall accomplished')
rate = rospy.Rate(1)
PENDING = 0
ACTIVE = 1
DONE = 2
WARN = 3
ERROR = 4
action_server_name = 'record_odom'
client = actionlib.SimpleActionClient(action_server_name, OdomRecordAction)
rospy.loginfo('Waiting for action Server '+action_server_name)
client.wait_for_server()
rospy.loginfo('Action Server Found...'+action_server_name)
def feedback_callback(feedback):
print('i am printing feedback')
def callback(msg):
# logic for wall following
client.send_goal(Empty(), feedback_cb=feedback_callback)
state_result = client.get_state()
while state_result< DONE:
rospy.loginfo("Doing Stuff while waiting for the Server to give a result....")
print("Progrma for wall following continues")
rate.sleep()
rospy.loginfo('state result', state_result)
if state_result == DONE:
print('Success')
elif state_result == WARN:
print('WARNING')
else:
print('ERROR')
rate.sleep()
var = Twist()
sub = rospy.Subscriber('/scan', LaserScan, callback)
rospy.spin()
This program is for the Action Server:
import actionlib
from rosject.msg import OdomRecordResult, OdomRecordFeedback, OdomRecordAction
from geometry_msgs.msg import Point
import math
class OdometryClass(object):
_feedback = OdomRecordFeedback()
_result= OdomRecordResult()
# creating action server
self._as = actionlib.SimpleActionServer('record_odom', OdomRecordAction, self.goal_callback, False)
self._as.start()
rospy.init_node('Coordinates', anonymous = True)
rospy.Subscriber('/odom', Odometry,self.callback)
#self._pub = rospy.Publisher('cmd_vel',Twist,queue_size=1)
self.rate = rospy.Rate(1)
def goal_callback(self,goal):
print('Goal Recieved')
success = True
self.i = 0
while True:
if self._as.is_preempt_requested():
success = False
self._as.set_preempted()
break
self.instance_variable.x.append(self.a)
self.instance_variable.y.append(self.b)
self.instance_variable.z.append(self.c)
self._feedback.current_total = math.hypot(self.instance_variable.x[self.i+1]-self.instance_variable.x[self.i], self.instance_variable.y[self.i+1]-self.instance_variable.y[self.i])
self._as.publish_feedback(self._feedback)
self.i += 1
print ('current distance travelled ', self._feedback.current_total)
self.rate.sleep()
if not success:
self._result.list_of_odoms = self.instance_variable
rospy.loginfo('The list of cordintes', self._result.list_of_odoms )
def callback(self,msg):
self.instance_variable = Point()
self.instance_variable.x = [0]
self.instance_variable.y = [0]
self.instance_variable.z = [0]
self.i = 0
#self._pub.publish(speed)
while True:
self.a = msg.pose.pose.position.x
self.b = msg.pose.pose.position.y
self.c = msg.pose.pose.position.z
self.rate.sleep()
if __name__ == '__main__':
OdometryClass()
rospy.spin()
Thank you for the help
