To use model plugin, how should I change cmakelist?
Failed to load plugin liba_model_plugin.so: liba_model_plugin.so: cannot open shared object file: No such file or directory
The above error appears
Hi @tlatmdgus19589 ,
You indeed need to change the CMakeList.txt file.
More instructions can be found here:
